Hush sound solution from 307
08.05.2020 21:28 # 1
Pilstols
Hello everyone, friends.
For a long time, especially when the vehicle was exposed to water for a long time (rain, etc.) , the sound of water was coming when braking or suddenly accelerating. There was a constant sound of water as if I was carrying water in half a carboy. It increased in winter and disappeared in the middle of summer.
While researching, I read that there might be water accumulating on the rocker in the forum, but it was all possible. I took the weekend and looked a bit. the sound was coming from the left side, the water drainage strikes my hand as I moved my hand over the back of the thin ledge on the underside of the rocker.
They were clogged with mud and I opened it with a little bit of control pencil, expanded a little and removed the water. (water splashed in the video below the left front door)
the place where the water came in was a small tear on the underside of that friend, whatever the gasket, the wick, or whatever the name was around the left rear stop, the bottom of the stop was also wet. I siliconed it a little bit, thinking it was entering from there. There is no silence left now. I hope the silicone will also be a solution, I will check from time to time.
If there are friends who have a silent voice in this way, I suggest they try this way.
[TUBE] w5jyp81cjfs [/ TUBE]
08.05.2020 21:28 # 2
whisky
the same thing happened to me when using 307. As you said the rocker expense was clogged. and water entered the trunk and the water that had entered had accumulated in the spare wheel pool.
