humming sound from the bottom |
| • Homepage » PEUGEOT MODELS (FAULTS AND SOLUTIONS) » All Questions About Your Vehicle | |
| 08.05.2020 15:28 | # 1 |
sercinho |
| 08.05.2020 15:28 | # 2 |
voodoo |
Well, let me tell you exactly the name of Turkish but I don't know exactly, there are bearings on the wheels, they have to change every 70.000 kilometers in 206's, if you move to the bookcase :)
| 08.05.2020 15:28 | # 3 |
If the wheel ball is scattered, it gives a very disturbing noise when the vehicle is moving, especially when traveling at a speed of 100 km or more. Whether the vehicle is idle does not change anything ... I think the sound of the engine is interrupted when I press the gas ... If the problem is in the ball, you will notice that there are models with abs and abs .....
| 08.05.2020 15:28 | # 4 |
The same complaint had been in me for 15 days, I went to the rot-balancer I went before, I turned the back wheels with the machine and listened, I did not get the output from the right rear wheel bearing, but I could have the bearing in mind as soon as possible. |
| 08.05.2020 15:28 | # 5 |
sercinho |
Thank you friends but I do not understand, it does not come to the pressure of the gas, my brother does not come to me, the pressure to the gas does not come to me, I think I was superintendent, I hope it is from the roulman, but it does not come when I throw it to the box, it is unreasonable to arrive in the transmission, it is unreasonable that 44000 km vehicle could not be understood.
| 08.05.2020 15:28 | # 6 |
I have that same problem
| 08.05.2020 15:28 | # 7 |
sercinho |
I wonder if there is another in my bearing
| 08.05.2020 15:28 | # 8 |
If it comes out of the gas, it is very likely that it comes from the ball of gearbox. It was chronic, my master told me .. I hope it is not like I said .. But when you show it, ask me what I said ..
