Humming sound after 60km
Homepage » PEUGEOT MODELS (FAULTS AND SOLUTIONS) » 308 (After 2014)
23.10.2022 19:16 # 1
Ayken
Hello
2018 I just joined you by buying 308 diesel automatic vehicles.
after 60 corners in my tool There is a steady humming sound.
It doesn't matter in gear or idle. is coming.
about 1000 after getting the tool I've done a long road in km, the car doesn't accelerate when I don't press the gas when I step down the ramp
Of course, I don't know if this is related to the cut off, but it felt strange. The person I bought it from has just installed the front tires and discs. But the rear tires are pretty old.
and a little glitch on the way when you pass through the area, it feels as if it will slip from behind, but it recovers immediately without any intervention. Is it normal in this model? At the inspection they told me to have the rear shocks checked.
in addition, right and There are noises coming from the left rear door (I'd say like squeaking and squeaking) and I'm waiting for your solution suggestions.
also my choice in Istanbul I'm also waiting for your European side master suggestions.
thanks everyone in advance
24.10.2022 16:25 # 2
talip206
Wheel bearings can make noise, making the same noise in gear or idle, increasing the possibility of wheel assembly.
Rear slip is due to the structure of the torsion system. It's not something to worry about, you'll soon get used to it.
Take silicone spray on the door seals and plastic parts for incoming noises
24.10.2022 19:43 # 3
Ayken
thank you for your answer
