hum on the right wheel
08.05.2020 14:51 # 1
hhuzun
Hello friends.
my 307 sounds humming right on the way going; it is as if there is a friction while pressing the brake. I removed the wheel and looked. I couldn't see anything; but when the speed of 50 km exceeds, the hum begins; why could it be; I am currently driving the car. does it make a big problem?
let's 2010-08-06 17:29:20
08.05.2020 14:51 # 2
Faruk
The ball of the wheel that had sounded had to change, I had a problem with the company vehicle, the service had changed the ball. go to the service there is a short job ..
08.05.2020 14:51 # 3
pads are making noise how many km have you last changed?
08.05.2020 14:51 # 4
hhuzun
their pads are 5000 km; I looked tightly and it wasn't a problem; it can be on the ball, now it's always a holiday; garages are closed; I go slowly until the holiday is over; thanks for informing again
08.05.2020 14:51 # 5
haruncoskun
that sound comes from the bearings
08.05.2020 14:51 # 6
10ur1
I do not think that the sound of my brother from the bearing may have a lot to do with the brake
08.05.2020 14:51 # 7
acad
it comes from the belly ball, you have to change it.
08.05.2020 14:51 # 8
I definitely have the same problem with the bearings, the bearing is drilled and the oil inside is running out, so it makes sound, you do not hear it after a certain speed.
respects
