hub balls and uninterrupted sound
08.05.2020 17:42 # 1
ibrahimtekinsoy
206+ 1.4 hdi (60.000 km) I bought recently had a buzzing sound in my car. my repairman friend said that he was due to the hub balls. changed on Monday. The next day, I realized that the sound increased much more, I went to the rot balancer, said that the front balls we replaced were redistributed and there was no problem with the rear balls. He said, "Replace the hubs together with the particle hub balls." today we changed the front hub balls and the back hubs together. There was no sound for the first 15-20 minutes while coming home and then started again, so there is no change. What do you think might be like there is a very loud humming noise as if I was driving a truck, there was very little noise before changing the balls at first, now I regretted changing too much. I am glad if you show me a way, friends who know how to follow a path. thanks in advance ...
08.05.2020 17:42 # 2
konyali42
interesting.
08.05.2020 17:42 # 3
ibrahimtekinsoy
thanks
08.05.2020 17:42 # 4
NEMIDAR
THERE IS 206+ ROAD SOUNDS THAT IS SOURCE FROM US ROADS, NOT 50% OF THE VOICE ROAD.
IF YOU CAN HEAR THE WEDDING ONLY THE TIRE SECT NEEDS TO BE MADE GOOD.
08.05.2020 17:42 # 5
ibrahimtekinsoy
thanks for your interest, friends. There are no accidents in the vehicle. He said to the lathe, to the hub and to the carrier. There is no problem. He said there is no oval. I wanted to disassemble the gearbox, I did not disassemble it because the same sound continues when I shift the gear out there is no reduction. (On the internet, if the gearbox was idle, it would say that the sound would be cut off or at least decrease.) I'll go to the authorized service tomorrow. I did not go to not give too much money, but I already paid extra and I had a lot of time ... I will share where and how the problem was solved. thanks for your interest again ...
