hub ball
08.05.2020 17:16 # 1
cnrars
Hello,
Yesterday my car's & nbsp; hub ball changed, it was coming from the front. After the ball has changed, while the vehicle is in motion, it sounds like a bird, it sounds like a bird, and it comes out, it stops when it touches the brake, and when it goes very, very slowly, it sounds more like a full body, why can they be? pads changed 2000 km ago, there was no such sound before, by the way
08.05.2020 17:16 # 2
cinar87
may be due to the lining process of the pads. As soon as it comes out of the bearing, hum comes. I recommend you to use it for a while, because the weather is cold and rainy, some parts of the vehicle may have thermal expansion, slight rust and very little oxidation. These are sufficient reasons for sound. the pads will decrease as they get used to the disc. By the way, what brand of brake pads you use, if you are a delphine, you should know that sound won't go away
08.05.2020 17:16 # 3
cnrars
[QUOTE = cinar87] may be due to the lining process of the pads. As soon as it comes out of the bearing, hum comes. I recommend you to use it for a while, because the weather is cold and rainy, some parts of the vehicle may have thermal expansion, slight rust and very little oxidation. These are sufficient reasons for sound. the pads will decrease as they get used to the disc. By the way, what brand of pad was used, if it is delphi, it will not sound. It was 5000 km, I went to the service again in this buzz, they asked for a lot of money, they said that the hub ball should be changed. There are those who know ostim in Ankara, there is ABK performance, I went there, only the ball of ball has changed, there was only buzzing before, okay buzzing passed, I just went to the market, a disastrous buzzing when the brake pressed and sounds like huh huh huh every time and The sounds may sound even more like in the round. I never asked what the brand is, by the way, it sounds so loud that a man on the road turned to look at the car, noluyo ya ya, that degree
08.05.2020 17:16 # 4
cnrars
friends, I went again, there was a place where the ball entered, not knowing the center, there was a curvature in it, the problem was with it, the ball was dismantled while removing the ball :( but I did not give money of course :)
08.05.2020 17:16 # 5
xMEGANx
Why would it be oblique? I have that problem.
08.05.2020 17:16 # 6
cnrars
My vehicle was damaged from the back, I wrote here last month, it might be related to it.
08.05.2020 17:16 # 7
msk_sansal
I had a buzzing sound from the front today, the hub balls have changed, the hum of the front wheels has been decreasing, but still continues. Do you think & nbsp; is normal? They say there is a winter tire as a tire. & nbsp;
08.05.2020 17:16 # 8
msk_sansal
Take a hand, brothers are rewards: (& nbsp;
