+ HP "Graded"
08.05.2020 13:56 # 1
The task of the shaft is to control the intake and exhaust valves. As a result of the Egzantirik shaft modification, one of the oldest and most efficient ways, a power increase of up to 35% can be achieved.
High-grade versions keep the opening and closing times of the valves long, allowing more fuel and air to enter the combustion chamber per unit time.
Therefore, more burning takes place. This sounds more powerful. According to the angles and adhesion of the cams on the shaft, torque or power is affected. Pointed camshafts open the valves early and increase the torque, while large crested cams are preferred to increase power. High-grade camshafts also increase the idle speed of the engine. In doing so, Ancan can cause the engine to run unstable at idle. For an efficient modification process, it is useful to develop other mechanical and electronic parts that provide the movement of valves outside the camshaft. For example, valves, valve springs, camshaft pulleys, brain program, ignition system.
LIFT:
The lift is the value that shows how much the camshaft presses the valves.
DURATION:
It is the degree measurement when it comes out of the valve bed.
OVERLAP:
It is the degree of time that the inlet and outlet valves are open at the same time. The opening number of the input camshaft is calculated by adding the closing number of the output camshaft.
POWER BAND:
It is the rev range that the camshaft can efficiently deliver.
How Much Power Gives the Grade Camshaft:
The camshafts produced for street cars are capable of generating power between 10 hp and 25 hp according to their rating and user choice, while the camshafts produced for racing cars can produce powers up to 80-100 hp.
08.05.2020 13:56 # 2
uc9096
Thanks a lot, very nice information ..
08.05.2020 13:56 # 3
sinan-s
Thanks for the information ...
08.05.2020 13:56 # 4
THANKS FOR SHARING
