How to wake 206 out of Safe Mode
08.05.2020 21:04 # 1
mcfearcombat
Hello, I had an air flow flow meter failure in my 1.4 HDI vehicle in the past months. With the occurrence of the malfunction, the vehicle got into safe mode and started entering the cutter at 3000 rpm.
The fault is resolved. I have been using it in safe mode for a while. When I talked with the master to remove safe mode today, he said that it would be removed from Ecu with software and that it would cost 300 TL.
Is it necessary to enter the software to remove Safe mode, cannot be removed through the diagnostic program over obs? I would be glad if you can express your ideas.
08.05.2020 21:04 # 2
kayaca
my opinion is that if you clear the error with the diagnostic device, it turns out that the abs lights and the airbag light were on, when the battery ran out, we connected it to the fault detection, we deleted it.
08.05.2020 21:04 # 3
Alicilik
The software is useless unless the flow meter is corrected. The engine adjusts according to the air temperature in the flow meter.
Peugeot Forums - Peugeot Fan Club © 2025
FromOwner.co.uk — Buy & Sell Directly from Owners in the UK. No dealers. No commissions. Just from owners.
