HOW TO UNDERSTAND VOLANT FAILURE
08.05.2020 14:57 # 1
furkan
How to understand flywheel failure in 110 hp diesel vehicles with ACABA SPRING flywheel
08.05.2020 14:57 # 2
I do not know the difference between spring and spring but the flywheel problem usually occurs when you press marsa. If the kite sounds, it may be volant. The result depends on the mars gear. Koliva 2010-11-17 12:34:59
08.05.2020 14:57 # 3
furkan
I thought it was what you said, but there were different malfunctions in the spring flywheel, for example, I was curious about the shaking while I was trying to vibrate while the vibration sounded like shaking.
08.05.2020 14:57 # 4
I did some research. In England, vehicles with this thread were recalled and made under warranty. They had 5-year warranties.
08.05.2020 14:57 # 5
I continued my research. It is called "dual mass flywheel" which you call spring-loaded flywheel. I think the reason for saying spring is because of the bow inside. What I will write next is another translation and translation.
The flywheel, which normally consists of a mass layer, consists of 2 parts on this vehicle. Between these two layers there are suspension springs. Instead of these springs, there are also flywheels that provide this suspension with hydraulic oil.
The main function of this part is to reduce the vibration caused by the diesel engine and thereby not transmit this vibration to the vehicle's suspensions and assemblies, gear box. It provides a more comfortable and quiet drive and lengthens the spine. However, one disadvantage is that when it breaks, it clears grip and everything nearby.
In response to your question, there may be tremor in the steering. You could feel this tremor in gear, even on the seats.
And it's a rather expensive piece to replace.
Koliva 2010-11-17 13:52:22
08.05.2020 14:57 # 6
furkan
yes, it trembles upon departure
08.05.2020 14:57 # 7
[QUOTE = furkan] yes shaking on departure [/ QUOTE]
Well, aren't you suphelected by other pieces? Because volant failure is the worst scenario. It seems to me that I can be without grasping.
08.05.2020 14:57 # 8
furkan
In this system, the price of the spring with a clutch spring without a flywheel is 1250 TL including the labor cost of 500 TL.
08.05.2020 14:57 # 9
oguzhan29
show somewhere brother
08.05.2020 14:57 # 10
furkan
I checked the service 110 hp diesel problem, they said this is the same problem in c4
08.05.2020 14:57 # 11
furkan
http://www.youtube.com/watch?v=veaokdiy0us
http://www.youtube.com/watch?v=3venık8uxqs&feature=related
08.05.2020 14:57 # 12
furkan
I wonder if I replace it with fixed flywheel
