How to Understand Gasket Burned
08.05.2020 17:14 # 1
Burak
There are those who say that my car is burning a gasket. How do I know how it is burning? I tell you a few symptoms, tell me what might have happened. br>
mekanuaes 2012-12-27 21:46:58
08.05.2020 17:14 # 2
xMEGANx
Exhausting White Smoke from the Exhaust
As the temperature never drops, it is constantly high.
There is foaming in the radiator water.
but it is not a very curious situation =)
reacts like this uncle car exactly.
[ TUBE] OfiiRl3sQ9M [/ TUBE] xMEGANx 2012-12-27 21:46:04
08.05.2020 17:14 # 3
Serkan
The vehicle throws excessive white smoke in the mornings, water or oil may decrease.
Open the lid of the container in which we put water in the engine for the morning, let the person start the car and let the gas burn as the gas emits and the gasket burns as the gas rises.
08.05.2020 17:14 # 4
Burak
There is a lack of oil and water especially in oil, seriously exhaust smoke pattern fora already water is rising, I do not know about it, but if these three are already burned, do you mean?
08.05.2020 17:14 # 5
Serkan
Unfortunately, it looks like that, mister. "Unhappy"
08.05.2020 17:14 # 6
Burak
ooyyy mountains! oooyyy & nbsp; "Unhappy" & nbsp; "Cry" & nbsp; Well, what is the cost of this?
08.05.2020 17:14 # 7
Serkan
Gasket is between 40-60 TL but labor costs are expensive, I think the cover should be grinded. Something between 200-250 can come up.
08.05.2020 17:14 # 8
Burak
would it take long?
08.05.2020 17:14 # 9
Serkan
It has 2-3 hours of work, but it can grow because it will go to stoning or something. They will probably come and go to you in the evening.
08.05.2020 17:14 # 10
Burak
apparently I'm taking the road to Saturday apparently
08.05.2020 17:14 # 11
sboz
There may be excessive pressure in the expansion vessel. Radiator hoses may be hardening. You can understand from here. workmanship etc. It cost 500 lira. So it's not 250 lira.
08.05.2020 17:14 # 12
Burak
[QUOTE = sboz] There may be excessive pressure in the expansion vessel.Radiator hoses may be getting too hard.You can understand from here. I changed it. workmanship etc. It cost 500 lira. So it is not worth 250 lira. The cover grinding is not done below 100 lira. If you look from it, it will find 400 lira. they do something, I should have it built in the industry, not a service vehicle
08.05.2020 17:14 # 13
Burak
There was a school song as if the school road goes straight and the children are going to feast.
08.05.2020 17:14 # 14
406 hdi
Hello friends, I recommend my car peugeot 406 2l 110 begir diesel 2003 December output 360,000 km first, hdi the engine is very durable, I would not repair it, I was putting anti-gel water in my car yesterday, I repaired the water cap in August, I saw a lubrication again. water did not repair this car well or it may have burned the gasket again.
08.05.2020 17:14 # 15
erkan307
First of all, how to get it repaired, how to get it repaired, the car that burns the gasket, the top cover is opened, and the gasket equipment changes, it gets worse, and how do I understand it? wait for a while, the water starts to boil, and if it overflows, the unregulated malfunction is still going on.
08.05.2020 17:14 # 16
talip206
If there is no gasket, there are two more possibilities.
Some vehicles may leak water when the thermostat seals the gasket. The cost is cheap.
The second possibility is that there are oil and water channels in the oil cooler. If there is an oil leak under the engine, it may indicate the oil cooler. Of course, these are the places to look if there is no gasket problem.
08.05.2020 17:14 # 17
rzy.dnz
If you have burned the gasket, your friend, who will throw out at least 1000 TL, will be over as soon as possible.
08.05.2020 17:14 # 18
ssakyel
Get well soon.
08.05.2020 17:14 # 19
gemlikli_55
I took it out from the industry: (the gasket burned, the moment was overheated, the water was reduced without any pressure, the water went out, the engine was exhausted. the muffler is making a sound more than 2 months ago I think it will find 3500 to change in the exhaust, unfortunately.: (((((
13.08.2021 18:56 # 20
Pejjj0.206
Thanks for your knowledgeable suggestions.
