How to Understand Airbag Explosion
08.05.2020 20:23 # 1
enes_468
slm friends I'm going to buy a vehicle 206 xline passenger airbag i crack like in the picture how do we know if this airbag has exploded before. the friend says he has cracked due to his knee support. ???
08.05.2020 20:23 # 2
Oktkor
If you take it to a good master, when the front teams check the connections or something, they can easily find out if they are hit by the front. I can't say anything cracked or something. So what kind of knee leaning friend.
08.05.2020 20:23 # 3
talip206
A common situation is that the rate cracks. But it is useful to have it checked.
08.05.2020 20:23 # 4
samet206
If there is a trace like a frame in the region rather than a one-sided fracture, it is obvious as a patch when you look at it.
08.05.2020 20:23 # 5
ziya alp
chronic problem breakage of the vehicle is normal
08.05.2020 20:23 # 6
yigit_dark
There is a crack in my vehicle that will make it very small. Perhaps it could become this if pressed hard. I don't think this will happen if airbag bursts. You can still connect it to the computer. You will feel comfortable.
08.05.2020 20:23 # 7
Peugeot35
If there is no rupture in the form of a frame, the place with only the part you show is not opened. The airbag that opens is not like this, when the human texture is broken, whatever we do is not like the old one. but the chestpiece changes.
08.05.2020 20:23 # 8
I have that same problem. the same is because of the knee rest, mine is about 2 cm or so, someone knocked the knee. Big smile ) I had to brake suddenly, we were looking at each other, a sound called the roof, then what happened back was 7-8 cm crack like in the photo.
08.05.2020 20:23 # 9
CemDemiral
Legal warnings about not taking and repairing cracked-chested vehicles If the cracked chest is repaired and sold in vehicles with an airback, then the buyer will be subject to severe sanctions to the seller if the airback is not opened in the accident that results in a fatal or similar result.
my advice is stay away from cracked chested vehicles. Because the chest with burst airback has to change, so that friends are not left that way.
08.05.2020 20:23 # 10
enes_468
Thank you all.
