How to tire 195.50.16 for 307
08.05.2020 16:28 # 1
tayfur
I'm thinking of wearing rim-tire 195.50.16, right now & nbsp; There is 195.65.15 rim-tire, I will enlarge the rim, but I will not increase the base, I will drop the cheek, I guess that it will not affect the fuel much, but how it stops in the vehicle comfort & nbsp; What would you recommend if you use a lot of dummies
08.05.2020 16:28 # 2
KenBlockJR
No way. It would be 205/55/16.
08.05.2020 16:28 # 3
tayfur
so why not, it should be 205.55.16 but & nbsp; I think that it will look better on the cheek, which will have 195 base because you don't want to increase fuel, & nbsp; I will get 195-55-16 if there will be a lot of trouble, but 50 cheeks stuck in my head
08.05.2020 16:28 # 4
KenBlockJR
Since the tire diameter will be smaller, it has negative results.
My vehicle is 307 1,4 diesel. I use 205/55/16. Its original size in diameter is the same as 195/65/15. There is no change in fuel, there is an increase in road holding.
08.05.2020 16:28 # 5
06OzGuR06
I think why not? Falling from 205 to 195 alone reduces road holding. My advice is 205/50 / R16 & nbsp; It will be better. No problem. Road handling is important because you know. "Wink"
Fuel consumption If you want to increase it, lowering the cheek size also reduces the fuel consumption. There is no need to decrease the base size. This is my advice. "Smile"
06ÖzGüR06 2011-12-23 03:40:19
08.05.2020 16:28 # 6
tayfur
now my rims are 195.65.15 so there is no problem with handling & nbsp; Of course, if the road has 205, the grip increases, but I am a calm user, 195 I can say well, I think that there are 165 floors in my previous vehicle, 195 is quite enough for me & nbsp; "Smile"
I did not know that the fuel increased as the cheek fell if it would increase fuel 195.55.16 & nbsp; it will be my second choice, assuming that I am curious, I put on 195.50.16, how does the car stand, the rim does not look like it looks like I think the rims are original 5 arm 307 rims, & nbsp; I do not have any lowering in the vehicle, I am curious if the gap between the tire and the fender remains empty.
08.05.2020 16:28 # 7
06OzGuR06
When the cheek is dropped, the fuel decreases as soon as it increases. As you say, it will not be bad, as you say 195 base will be enough. Your choice is still. So if you go down from 55 to 50 cheeks, there may be a small decrease in fuel.
08.05.2020 16:28 # 8
KenBlockJR
There is no such thing as fuel decreases when the cheek drops.
Comfort decreases. Moreover, since you reduce the original diameter, the car will lower, the speedometer will not show correctly etc. etc.
195/55/16 finding tires is both harder and more expensive.
It is exactly the same diameter as your original tire. The only tire you will use is 205/55 / 16. & nbsp;
You can also see it here:
< br>
KenBlockJR 2011-12-23 14:59:50
