How to tell INCH from the tire size
08.05.2020 16:52 # 1
Hi friends. I am thinking of buying a steel wheel. But when we look at how many inches are asked. How do we know this inch.
my tire sizes are as follows: & nbsp; & nbsp; 175/65 R14 82T says how many inches it is ...
& nbsp;
then something big or on the contrary, nothing small. or what is the most appropriate and how do we know?
thanks.
08.05.2020 16:52 # 2
MagicPerformance
14``yours
08.05.2020 16:52 # 3
BULUT06
the end of the r written inc dir others (175 writing width tire) (cheek event at 65) must be taken and appropriate in the spring 205-40-17 this is generally used if you will ride with the family in me never enter this regiment
08.05.2020 16:52 # 4
[QUOTE = BULUT06] incl r at the end of r (other than 175 writer width tire) (cheek event at 65) must also be taken and suitable 205-40-17 this is generally used if you will ride with the family in me never enter this regiment [/ QUOTE] < div> & nbsp;
& nbsp;
& nbsp;
& nbsp;
generally two people get in, but generally because the circle of friends is crowded, the vehicle is generally 4 or 5 people. I don't understand what this has to do with the number of people.
08.05.2020 16:52 # 5
[QUOTE = umutrizaergen] 14``yours are [/ QUOTE]
okay ... thank you ... so how can i get 15. Would it be appropriate to grin? Or if it is 15, would it be harmful?
08.05.2020 16:52 # 6
BULUT06
Approaching to the ground, the size of the rim decreases, the distance decreases. When the 3,4 person gets on, the tire cart cart is rubbed, the rim in the bumps will be broken.
08.05.2020 16:52 # 7
yes you are right right then what exactly should you give me a measure? He said the cheek should be wide.
08.05.2020 16:52 # 8
I have previously updated the forum again. steel rim caps. Would you recommend them?
& nbsp;
08.05.2020 16:52 # 9
BULUT06
195-55-15 is used, generally I used it in 206 does not cause any problems & nbsp;
08.05.2020 16:52 # 10
[QUOTE = BULUT06] 195-55-15 is used, I usually used it in 206 does not cause any problems & nbsp; [/ QUOTE]
okay thanks. There are also steel rim caps in the forum. what do you think about them.
& nbsp;
08.05.2020 16:52 # 11
BULUT06
money-related rim tire 1500 lira when you give it to you, wherever you look, you can give it 1000 lira top cover look ornamental monetary main
08.05.2020 16:52 # 12
yes monetary situation is a little "Smile". of course if I give the rim look, I say if I try it on the internet.
08.05.2020 16:52 # 13
LIKE ......
08.05.2020 16:52 # 14
BULUT06
go put it in an accessory, pick it up, look at it, and if you don't like it, don't worry if you go into detail, this cover 5bijon pejolar 4bijon smart cunning man says cover night never play cover go go rim is a big distress as someone who uses his 4th rim
08.05.2020 16:52 # 15
I never thought the bolts. valle. go until you write it, look at it and see it .... uncle bursa but here the prices are very cheap. i was going to buy a glass windbreaker kiiii & nbsp; 2 of them here 90TL. There is not even 4. the price is 70-80tl. I took a look at it from the internet. 45TL. Anyway, do not get distracted. They call the center of the modya, but the prices are very cheap here
08.05.2020 16:52 # 16
BULUT06
There are parts that are not even on the black market of Ankara. If you get a master, we expect you to put it. We look forward to you.
08.05.2020 16:52 # 17
KenBlockJR
For 15``:
185/55/15
195/50/15
195/55/15
For
16``: & nbsp;
195/45/16
195/50/16
205/45/16 For
17``:
205/40/17
you can install
KenBlockJR 2012-06-24 20:26:05
08.05.2020 16:52 # 18
mine is 14`` & nbsp;
then 15``?
