How to reset the maintenance mileage? |
| • Homepage » PEUGEOT MODELS (FAULTS AND SOLUTIONS) » 207 | |
| 08.05.2020 16:02 | # 1 |
| 08.05.2020 16:02 | # 2 |
Turn the ignition. When full maintenance is km, long press it flashes. Then it starts counting down from 1o. It writes about 30000 km (mine is 206).
| 08.05.2020 16:02 | # 3 |
I agree with ole exactly in the 206's, I reset the ole
| 08.05.2020 16:02 | # 4 |
Engin Tepe |
Pug pug stop try if you want :)
| 08.05.2020 16:02 | # 5 |
[QUOTE = Engin Tepe] Pug pug stop try if you want :) [/ QUOTE] I have not tried. Does anyone suggest another way? |
| 08.05.2020 16:02 | # 6 |
[QUOTE = okan0665] [QUOTE = Engin Tepe] Pug pug stop try if you want :) [/ QUOTE] I have not tried. Does anyone suggest another way? [/ QUOTE] There is. With Peugeot Planet 2000 system, you can reset your vehicle by connecting it to the computer. ![]() This must be the peeling chip. Turn off the ignition, press the right button on the instrument panel and keep it pressed. On the other hand, turn over the ignition and start the car. He needs to count backwards from 10. When the census was over, it was reset. |
| 08.05.2020 16:02 | # 7 |
close the contact completely, press and hold the right button on the screen and counts the contact back from ac 10 and wait and the result will be reset.
| 08.05.2020 16:02 | # 8 |
Thanks guys, it has been reset. By the way, I made 2000 KM but now, we will go with 7000 remaining :)
