How-to Requests.
Homepage » PEUGEOT MODIFIED PLATFORM » How To
08.05.2020 14:02 # 1
hasimayaz
Let's gather how we want to make friends under this title. We will evaluate your requests as soon as possible and publish them as Articles & Technical drawings and Translation.
If you have technical issues and have an illustrated inventory, do not hesitate to open a topic in this section.
You must comment on the subject you want to add to the article or see it wrong, positively or negatively. In this way, I hope that our technical database will expand further. We will carry it here as a link in our how-to corner on the main page.
For malfunctions and undiagnosed troubles in your vehicle, use the FAULTS AND SOLUTIONS ABOUT YOUR PEUGEOTS .
08.05.2020 14:02 # 2
savi_206
I wore armrests on my vehicle last week.
08.05.2020 14:02 # 3
Carmania
It has been a very nice title. Clap
08.05.2020 14:02 # 4
MirakGTI
let's take it easy
08.05.2020 14:02 # 5
HakanGokdemir
Haşim you thought very well, thanks for offering such an opportunity, the first request is with me, then with your permission;
I ask for help on how to change the oxygen sensor for my Peugeot 306 griffe model car, can I do this or do I need to go to the service because a pc connection may be required?
08.05.2020 14:02 # 6
hasimayaz
[QUOTE = hakan1203] Haşim you thought very well, thank you for offering such an opportunity, the first request is with me, then with your permission;
Hakan did you clean the butterfly ?? clear it up before .. sensor job trial and error job .. just the computer you need to clear the fault
08.05.2020 14:02 # 7
HakanGokdemir
Yes, I cleaned the butterfly, the malfunction lamp had gone out after they had been put into service, but they said it could burn again. Let's see that I expect the gasoline to be finished after that, the process to be done will be obvious, maybe nothing will be needed ...
08.05.2020 14:02 # 8
hawim brother :) hakan brother knows the service maintenance light burned but the day passed but it has been over for 2 days hic does not burn, I have 5 more thousand days of care, is there any warning or not?
08.05.2020 14:02 # 9
HakanGokdemir
Dear moderator Emrah;
For malfunctions and undiagnosed troubles in your vehicle, use the FAULTS AND SOLUTIONS ABOUT YOUR PEUGEOTS . LOLLOLLOL
Extract from HaşimAyaz ...
hakan1203 2009-03-23 10:22:06
08.05.2020 14:02 # 10
In 307s, the screen with the radio and the clock
writing can be written. how to do ???
08.05.2020 14:02 # 11
hasimayaz
[QUOTE = ErAyZ] 307s radio and clock display
It is a job that requires advanced electronic knowledge. Our article was prepared with a superficial expression.
08.05.2020 14:02 # 12
master
I think a pandizot for 206. I want to do it myself because I can not buy crazy prices like 160-200 or have it done at the carpenter.
I request illustrated visual information on this subject.
08.05.2020 14:02 # 13
hasimayaz
[QUOTE = master] I am thinking about 206 sponge. I want to do it myself because I can not buy crazy prices like 160-200 or have it done at the carpenter.
I request illustrated visual information on this subject. [/ QUOTE]
We can continue the topic here.
08.05.2020 14:02 # 14
BurcUMUL
The back tailgate of my car seems to me 5-6mm low. I showed it to the service but said normal. There is no problem with its closing. I checked some of the other 206 gti, but the ganel is not low but a few are similar to mine. Is there a way to adjust the tailgate?
08.05.2020 14:02 # 15
hasimayaz
[QUOTE = pug206gti] It seems to me that the back tailgate of my car is 5-6mm low. I showed it to the service but said normal. There is no problem with its closing. I checked some of the other 206 gti, but the ganel is not low but a few are similar to mine. Is there a way to adjust the tailgate? [/ QUOTE]
When I say low, does it go in too much?
08.05.2020 14:02 # 16
individual
Hi
I have some wishes too.
I want to make a few additions to the 307 van vehicle.
I want to buy the map reading and indoor lighting unit which is available in 308 premium pack.
First of all, what is the price of this?
Also, the submarine light on that unit needs to be activated.
Is there an oil temperature sensor in 307 vans although it is not found in the instrument panel
I am thinking of buying and installing a 307 cc indicator.
will it work one to one?
Will the oil temperature information on the CC indicator be active?
Can we convert the CC indicator I bought to the original km of my vehicle?
I am thinking of moonting the seat belt warning screen in the 308's to my vehicle.
I think it is necessary to change the seat belt set as well.
I would like to see which belt is fastened on that screen.
Good luck with
08.05.2020 14:02 # 17
Darkside
Haşim friend opened a nice subject ..
I want to replace my instrument panel like individual and replace it with a model with an oil temperature dial. Also, will the system be working on the screen while cruise control is activated on this panel?
Can my car's doors be locked after reaching a certain speed? We made several trials in the past months with other friends in this request, but we were not successful.
In fact, if I buy and replace the so called BSI, would it be too expensive or would I have a compliance problem? Because I think I had van-can is it difficult to manipulate this with a van-van system?
Thanks
08.05.2020 14:02 # 18
master
forgiveness: The subject is in the wrong place. It should have been in the following header (for 2 friends who wrote last.)
ALL QUESTIONS ABOUT YOUR VEHICLE
Rim, Spring, Tire Exhaust, Filter, Sound System Etc.
08.05.2020 14:02 # 19
hasimayaz
[QUOTE = individual] hi
Good luck with
[QUOTE = Darkside] Haşim friend has opened a nice subject ..
Thanks
First of all, it is a real appreciation that you are so curious about the technical details of your vehicles.
Both the 307cc and 308 models, which can be considered new in the market, and so to speak, have not yet fallen into hand, industrial environments. So unfortunately, what I write will not go beyond the advice.
If I say let's consult the authorized service for detailed attention, the competent service competencies are really ignorant about these issues.
3-4 years ago, we said to replace the dial of a friend's 106 GTI with a digital dial after 2000. Sockets were different, of course.
So we provided complete pinouts of old and new sockets and adapted them individually, or we thought we were.
The indicator was working roughly, but the worm gear and sensor did not fit the new indicator. We replaced it with a new one.
Km. km of vehicle. he didn't show his. We removed the eprom on the indicator and attached it to the eprom programmer with the bullying of being a computer engineer.
First, we made a backup of the current data. Km from Hex content. We thought we had found and replaced it with the eprom, which burned out.
It was easy and cheap to supply an 128k eprom from God. We bought a new eprom and reloaded it and fixed it after a few tries.
After all, everything worked, except for the fog lamp lamp. But we had a thousand regrets that we got infected in this business.
In ECU data diagram, oil temperature and level information comes from the same probe. Also I have not heard of a separate probe for the oil temperature.
BSI exchange is hard and costly. immo chips, switches, adjustment of the unit and new diagnostics. There are OEM kits on the market for super lock, but these kits usually work on the first brake after the car has been walked.
08.05.2020 14:02 # 20
individual
hostile
thanks for your answers and thoughts.
Actually, I have programmed eprom many times.
you actually gave me an idea.
because I have a different application in my mind.
I have revised works in the area where the warning lamps are between the 307 speed and tachometer.
There are approximately 16 warning lights in that area for headlight warning, ASR warning, battery warning, etc.
let's say there is actually a led.
I am thinking of canceling that area completely and installing an oled screen in that size.
I want to show the headlight on warning graphically on that screen.
it won't be like a 308 or 407 screen, so I can't communicate that much but
At least, I say the car will have a peugeot logo for 3 seconds on the first run.
I want seat belt warnings to appear.
In short, it is now up to my imagination and programming ability. the tip is open.
I thought the 307 cc indicator would fit my car exactly, but this explanation had a question mark in my head.
after all, this is untested.
but the difference between the 97 gti and 01 gti indicators should be more than the difference between the cc and the 5-door 307 indicator.
But when I have time, I think I can allocate enough budget for this job.
I want to at least make the process if I can't finish this job.
I never touch or communicate bsi. the job is a bit crippled.
I just want to show the additional hardware that I added on that screen.
I can do some visual sov.
at least 3.5 inch market-borne nav. I think I'll put your device there.
at least i will try.
Page : / 4
