How to replace the wiper?
08.05.2020 20:45 # 1
x571
I bought a pair of wipers from shock. I want to change this. I couldn't find how to change it. How can I change this type of wiper?
[TUBE] jy8g4v7p1h the [/ TUBE]
x571 2018-01-31 09:17:56
08.05.2020 20:45 # 2
onlycihan
It is the easiest type of wiper to change. If you open the clip and push it in the opposite direction, if you turn the wiper out of the wiper arm, think of it as a hook.
08.05.2020 20:45 # 3
x571
[QUOTE = onlycihan] is the easiest wiper type to change. If you open and push the clip, it turns out the wiper arm if you turn the wiper in the opposite direction. Think of the tip of the wiper arm as a hook.
I tried but I could not. I'll try again.
08.05.2020 20:45 # 4
x571
I had to push it back and forth a little bit. there is a problem now. Part of the glass in the driver's part remains undelected, why?
08.05.2020 20:45 # 5
onlycihan
Either it is not fully seated or the wiper is not suitable for your vehicle. In fact, it must take the curvature of the glass like a bow, but it does not mean anything
08.05.2020 20:45 # 6
x571
[QUOTE = onlycihan] Either it does not fit properly or the wiper is not suitable for your vehicle. In fact, it must take the bow of the glass like a bow, but it does not mean anything without seeing [/ QUOTE]
the old one left without wiping like this. I thought that it was old and broken. Where should we look at this? How should we examine it?
08.05.2020 20:45 # 7
If the springs on the metal arms of your wiper have lost its feature, my teacher does not wipe it completely because he cannot apply the necessary pressure.
08.05.2020 20:45 # 8
akk0212
wiper blade may have been warped
08.05.2020 20:45 # 9
x571
[QUOTE = sonerkyl] If the springs on the metal arms you put on the wipers have lost their feature, they will not be able to apply the necessary pressure, as it will not delete them fully. [/ QUOTE]
Do these springs change or should the arm be thrown completely?
[QUOTE = akk0212] wiper blade may have been skewed [/ QUOTE]
What should I do if iron is broken, will it recover manually?
x571 2018-02-01 20:59:07
08.05.2020 20:45 # 10
x571
the subject is up to date
08.05.2020 20:45 # 11
akk0212
can be corrected by trial and error
08.05.2020 20:45 # 12
x571
Indeed, the squeegee was broken. I twisted it with two hands and straightened it. they wanted 100 TL for a new one, left in my pocket Smile
