How to replace the door trim
Homepage » PEUGEOT MODIFIED PLATFORM » How To
08.05.2020 17:04 # 1
impact
Although I am not very sure, it does not dismantle there, I think I opened the door recently, I think it was a bit troubled, but there is a solution.
08.05.2020 17:04 # 2
ahmetismet
dismantling, teacher, I made the application that my friend wanted, I covered the fabric, not the leather. There are pictures in the link:
http://forum.peugeotturkey.com/forum_posts.asp?TID=23720&PN=1&title=modifiyem-bitmek-zereres%DDmler-eklend%DD
When it comes to
removal, there are 3 screws inside the door, unscrew them at the edges, remove the glass on and off buttons and the frame of the door opening handles. Then take the screwdriver and pry the plastic parts by prying on the hand. Recover inside nails (you may need to apply some force). Plastic nails may break if you push too hard, but don't worry, you will get 20-30 per 5tl. After you get rid of all the nails, lift it up, remove the speaker cables and the trim has been removed.
Your The armrest part you want to cover with fabric can be attached by melting the plastic from the inside, you can save the parts that have been melted with the utility knife. By fixing the coating you will apply with hot silicone, you can recover if you do the opposite operations.
Easy to come ...
08.05.2020 17:04 # 3
ahmetismet
I do not know how hot silicone will affect the skin ...
When you remove the molten plastic and put it back on again, it will be extremely solid if you do it ... seal it again with a soldering iron.
If the part you call it is not too worn out, I think it is no touch, but if you are going to be able to paint it, a few layers of paint using spray and varnish
08.05.2020 17:04 # 4
impact
I was just saying right, I remembered I had removed the mirror to repair it, then the armrest was pressed. you can either stick it with a soldering iron or japanese to stick it later .. & nbsp;
08.05.2020 17:04 # 5
ahmetismet
If the upholsterer wants solid money for the works you think, and I think he can, use the money you will give to workmanship to buy more quality materials and be even more elegant. I would be glad if you share the photos with the photos after applying them.
By the way, the car of the individual is ten numbers, but I saw that he was selling it recently ...
I worked very hard inside the car too I did so I wouldn't sell it for a few years ...
08.05.2020 17:04 # 6
[QUOTE = 307 bursa] I caught a product called nette plasti dip, how can I paint the upper plastic part with this? & Nbsp;
Anyone using or knowing this paint? It is easy to disassemble and does not leave any traces of anything interesting. This paint & nbsp; "Smile"
I never felt this plastic bottom but it looks like a nice thing. You're the first to do it. I say try.
08.05.2020 17:04 # 7
impact
It looks like a good scholarship, but the prices seem a bit high
08.05.2020 17:04 # 8
ahmed206
[QUOTE = 307bursa] I forgot this message so I am hooking the subject :)
I HAVE MADE IT :)))
Is there a photo ?
08.05.2020 17:04 # 9
barishrocker
If we put it here :) I think the owner before me was worth smoking. I need to get a hand on the flooring of the glass buttons ..
