How to Repair Resistance Failure?
08.05.2020 16:12 # 1
During the winter, drivers often encounter vision problems due to the mist formed on the rear window. The only way to remove the mist is to run the resistance. The only way to remove the mist is to run the resistance. However, the thin resistance wires that break for various reasons cause the drivers' head to hurt. However, these wires can be repaired in a few minutes with silver glazed paints sold in the market. Makes misting Even if you will forget its existence in the summer months, you can repair it when the rear window resistance fails. Resistance wires, which have a very thin and sensitive structure, either break while the glass of the car is wiped or the car stationwagon is broken during loading. These thin and sensitive resistance wires, which are connected parallel to each other, which warms up the misting in the rear window, show themselves by making misting when they break. Robust ones continue their duties. 5 minutes of repair Most users are lazy to have the broken resistance wire repaired. Going to the service for a simple wire seems like a laborious task. However, as the wires continue to break, the rear window will completely mist, and then the real problems begin. It would be wrong to wait for all wires to break to go to the workshop. With silver glaze conductive paints, you can repair your car's resistance in 5 minutes. Moreover, alone. How to repair the resistance? For repair, it is first necessary to determine which wire is broken. To understand this, the resistance is run. As the mist on the working wires is dissolved, the mist will remain in the area where the broken wires are located. The broken on the wire can easily be found in the area where the wheat is left. It is necessary to clean the surface before applying the silver glazed conductive paint on the broken wire. For this, you should wipe the surface with a damp cloth and without pressing too hard to avoid damaging other wires. After the cleaned floor has dried, a special cardboard with a space as thick as the resistance wire is placed on the floor in order to prevent the silver glazed conductive paint from sticking out. Then, silver glazed conductive paint is applied to that space, and the ends of two broken wires are connected. If there is no special perforated cardboard coming out of the box, both sides of the broken part can be taped to prevent the paint from overflowing. The most important point to note here is that silver glazed paints must be shaken well before use. After applying the paint, it is enough to wait 5-6 hours to dry. During this time, the resistance should not be operated. However, if you don't want to wait that long, you can keep a hair dryer on the dye and let it dry faster. Silver glazed paint can only remove the breaks in the rear window resistance. It is not used for damages in the main connection points of the resistance and resistance failures in the heated windows in the rearview mirrors of the windscreen and side windows.
08.05.2020 16:12 # 2
emin08
Thanks for information. Can I repair it with my normal hot solder, the electric cable is broken, which is connected to the resistance of the vehicle I use in the company? I heard that the glass could explode if done with hot soldering. Is it true?
08.05.2020 16:12 # 3
gozem
A good solution. Well, I have never been on the market so far
08.05.2020 16:12 # 4
insomnia
I am looking for more than this silver colored paint, even the loctıte dealer said Hönk.
