How to Repair Resistance Failure?
Homepage » PEUGEOT MODIFIED PLATFORM » Useful Documents
08.05.2020 14:05 # 1
How to Repair Resistance Failure? During the winter, drivers often encounter vision problems due to the mist formed on the rear window. The only way to remove the mist is to run the resistance. However, the thin resistance wires that break for various reasons cause the drivers' head to hurt. However, these wires can be repaired with silver glazed paints sold in the market in a few minutes. Even if you forget about its existence in the summer, you can repair it when the rear window resistance fails. Resistance wires, which have a very thin and sensitive structure, either break while the glass of the car is wiped or the car stationwagon is broken during loading. These thin and sensitive resistance wires, which are connected parallel to each other, which warms up the misting in the rear window, show themselves by making misting when they break. Robust ones continue to carry out their tasks. Repair is 5 minutes.Most users are lazy to have the broken resistance wire repaired. Going to the service for a simple wire seems like a laborious task. However, as the wires continue to break, the rear window will completely mist, and then the real problems begin. It would be wrong to wait for all wires to break to go to the workshop. With silver glaze conductive paints, you can repair your car's resistance in 5 minutes. Moreover, alone. How to repair the resistor? • First, it is necessary to determine which wire is broken for repair. To understand this, the resistance is run. As the mist on the working wires is dissolved, the mist will remain in the area where the broken wires are located. The broken on the wire can easily be found in the area where the mist is left. • It is necessary to clean the surface before applying the silver glazed conductive paint on the broken wire. For this, you should wipe the surface with a damp cloth and without pressing it to avoid damaging the other wires • After the cleaned floor has dried, a special cardboard in the middle of the box, which is as thick as the resistance wire, is placed on the ground so that the silver glazed conductive paint does not overflow. Then, silver glazed conductive paint is applied to that space, and the ends of two broken wires are connected. If there is no special perforated cardboard coming out of the box, both sides of the broken part can be taped to prevent the paint from overflowing. • The most important point to note here is that silver glaze paints should be shaken well before use. After applying the paint, it is enough to wait 5-6 hours to dry. During this time, the resistance should not be operated. However, if you do not want to wait that long, you can keep a hair dryer on the paint and dry it faster. The silver glazed paint can only remove the breaks in the rear window resistance. It is not used for damages in the main connection points of the resistance and resistance failures in the heated windows in the rearview mirrors of the windscreen and side windows.
08.05.2020 14:05 # 2
t@lip
Good information, thank you ..
08.05.2020 14:05 # 3
simsiyah
thank you Emrah continues to give information on everything :)
08.05.2020 14:05 # 4
Murat
I guess many people like me don't know how to fix this malfunction.
08.05.2020 14:05 # 5
ErkanKurnaz
nice sharing, health brother in their hands
08.05.2020 14:05 # 6
Can Duzyatan
I have not had any problems with the resistance until now, but I have saved the information you shared to my memory.
& nbsp;
It was a very practical method, thank you "Smile"
08.05.2020 14:05 # 7
BurcUMUL
Thanks for information . This kind of minor repairs are done by yourself, and when the fault is resolved, it has a distinct spiritual taste. & Nbsp; & nbsp;
08.05.2020 14:05 # 8
Onur
thanks for sharing
08.05.2020 14:05 # 9
deniz_206
emrah for the first time you did it dude always be useful share information ok "Big
08.05.2020 14:05 # 10
Ozgur
friends where can I find this paint ..
08.05.2020 14:05 # 11
hasimayaz
[QUOTE = uruk33] friends where can I find this paint .. [/ QUOTE]
& nbsp;
It is found in all Electronics. Silver circuit dye "/>
08.05.2020 14:05 # 12
Ozgur
thanks for the answer
08.05.2020 14:05 # 13
Haci
Good and useful information "Applause"
