How to remove the right rearview mirror?
08.05.2020 18:24 # 1
ahmet_bjk
Hello friends...
While my car is parked, someone has a little scratch on the right door, and the plastic parts around the signal under the mirror are opened and the mirror does not close.
I am thinking of removing the mirror and closing it securely again if there is no problem, but in my researches on the internet, I could not find any information about how to remove such mirrors.
How are these mirrors removed?
Thank you...
08.05.2020 18:24 # 2
Bugra
most likely you will have to remove the door trim. You will see how to remove the mirror when disassembling. the mounting location of the mirror shows it.
08.05.2020 18:24 # 3
cavit cevo
there are york screws holding the mirror that removes the door trim dismantled okay do not forget the cables of course bidet
Good luck with
08.05.2020 18:24 # 4
ahmet_bjk
I took the original pictures.
The plastic under the mirror is detached and the mirror does not close. What can I do to fix this. I pressed a little, but it did not close, so I did not force me to break things.
08.05.2020 18:24 # 5
ahmed206
Whoever made her mother cry. Get well soon bro. The cleanest thing is to remove it from the inside (flooring), otherwise you can break the nails and come easy.
08.05.2020 18:24 # 6
ahmet_bjk
From what angle I shoot in detail, the mirrors are manual, the aperture is only where the picture appears.
08.05.2020 18:24 # 7
ahmet_bjk
The photos I tried to take in detail.
08.05.2020 18:24 # 8
ahmet_bjk
It is not moving in any direction right now. I tried to remove the cover with the signal, but I could not. Do I need to remove the signal first, or will it open if I force it through the opening with a screwdriver?
