How to remove the airbag cover on the steering wheel |
| • Homepage » PEUGEOT MODELS (FAULTS AND SOLUTIONS) » 207 | |
| 08.05.2020 17:35 | # 1 |
I want to remove the heavy bag cover on my pegeout 207 steering wheel, If anyone has experience or knowledge on this subject, I would be glad if they share it
| 08.05.2020 17:35 | # 2 |
Alicilik |
There will be a hole under the steering wheel, push the metal part with the flat screw that can enter it, remove the bottom part, then stretch it and release the top. |
| 08.05.2020 17:35 | # 3 |
I don't know it is the same as 207, but 206 also has a hole under the steering wheel, a metal is going through the iron, and when it pushes that iron with a flat screwdriver, the cover throws itself. |
| 08.05.2020 17:35 | # 4 |
thank you friends I hope it's the same as 206 Is it easy to refit the cover
| 08.05.2020 17:35 | # 5 |
Bugra |
Well, if I was my knowledge and experience, I would never handle that airbag ...
| 08.05.2020 17:35 | # 6 |
The horn is not playing, sometimes it is playing, I will look under the cover.
| 08.05.2020 17:35 | # 7 |
there is a hole in the bottom of the steering wheel and a metal iron appears inside inserting a flat screwdriver and stretching the iron downwards but heavy bag lid does not come off
| 08.05.2020 17:35 | # 8 |
Hodja press the screwdriver on the wire, then hit the screwdriver sparrow from the bottom, it gets rid of the cover slots |
| 08.05.2020 17:35 | # 9 |
okay, sir, tomorrow morning I will try it like this; I just pressed it and try it forcibly
| 08.05.2020 17:35 | # 10 |
Do not forget to remove the battery terminal before this process! |
| 08.05.2020 17:35 | # 11 |
Why does Üpdat airbag explode? I will also try to open it, I asked him.
| 08.05.2020 17:35 | # 12 |
[QUOTE = koliva] Don't forget to remove the battery terminal before this process! [/ QUOTE] ++ div> even if you have removed the pole head, it is important to be careful so that there is a disability in the apparatus called airbag so that there is no disability ..
| 08.05.2020 17:35 | # 13 |
[QUOTE = halilefe] Why does Üpdat airbag explode? I will try to ask him to open it too. [/ QUOTE] Safety first ![]() |
| 08.05.2020 17:35 | # 14 |
| 08.05.2020 17:35 | # 15 |
Bunyamin.Kar |
I was going to disassemble the 306's steering wheel, but I couldn't disassemble the airbag, I think it hasn't been disassembled ever since it left the factory :) I did not move it from the right side, I hit it a few times from the left, I clicked a little bit around the place where the screw was with the hammer, I tried to stretch the steering wheel towards myself. did not say, anybody have an idea?
| 08.05.2020 17:35 | # 16 |
I have the same problem, the horn does not sound at all, and the airbag light is constantly on. |
| 08.05.2020 17:35 | # 17 |
Usdat, I tried to sting 206, I hit the bottom like I said, but there are only 2 sockets on the top and on the left they get rid of it but I could not save it from the bottom.
| 08.05.2020 17:35 | # 18 |
I want to grasp the subject. As far as I understand that we have not been able to remove the front cover of the steering wheel, we would like to remove this cover and check the horn for friends 206.
| 08.05.2020 17:35 | # 19 |
[QUOTE = themurat54] I want to hose down the subject. I removed it. First the battery comes out of the pole because the horn is stuck and the neighborhood is moaning. pull it out towards you First one side comes out, then the other side pulls out already Then there are two sockets when you disassemble it, you separate it completely |
| 08.05.2020 17:35 | # 20 |
[QUOTE = talip206] [QUOTE = themurat54] I want to hose down the subject. I had removed. First, the battery is removed from the pole because the horn is stuck and the neighborhood groans :) Then there is a hole towards the left back, insert a flat thick screwdriver into that hole and push the iron wire in it. One side comes out first, then the other side comes off already. Then there are two sockets when you disassemble it and you separate it completely. [/ QUOTE] & nbsp; There is an iron in the hole at the bottom of the steering wheel, there is a hole in the back of the left, did you mean it?
