How to remove the 307 indicator glass?
Homepage » PEUGEOT MODIFIED PLATFORM » 307
08.05.2020 19:01 # 1
byderebey
Hello friends .. my 307's indicator glass is dusty under it I want to clean it I would appreciate if warsa informs how to disassemble the glass is hard to inform ..
08.05.2020 19:01 # 2
muro_60
There are two holes under the indicator glass, it can be on the screwdriver so that it can be in the holes, pull it in and pull out the km time, how do you disassemble the tape, that is, after that, with the screwdriver, remove it, clean and plug it
08.05.2020 19:01 # 3
byderebey
[QUOTE = muro_60] There are two holes under the indicator glass, it can be on the screwdriver so that it can be in the holes, pull out the hour and remove the tape, so you can remove it with the screwdriver, then clean and install it [/ QUOTE]
It turns out, is that so?
08.05.2020 19:01 # 4
muro_60
yes, take out the complete disconnecting sockets, whatever you do, do not touch the hands, do not touch the hands, do not try to remove it.
08.05.2020 19:01 # 5
byderebey
I don't bother then :)
08.05.2020 19:01 # 6
muro_60
[QUOTE = byderebey] I don't bother then :) [/ QUOTE] If it is for dust, you do not touch the hands, you can wipe it back and put it back.
08.05.2020 19:01 # 7
byderebey
I'll see you tomorrow, thank you brother thank you ..
