How to remove the 307 front bumper and headlights |
| • Homepage » PEUGEOT MODIFIED PLATFORM » 307 | |
| 08.05.2020 17:05 | # 1 |
fexzi |
. With the help of a jack, we get bumper connections on the horse side and the bumper falls on your lap and this process lasts for 10 minutes. It holds 3 screws, after removing the screws, the headlights are ok :)
| 08.05.2020 17:05 | # 2 |
impact |
My brother, I was going to give you a video narration, but I did not have the opportunity to remove the headlights again, as my brother explained, the bumper goes down in 10 minutes and the headlights are connected with 3 screws
| 08.05.2020 17:05 | # 3 |
fatihgg |
I was going to say exactly, ask the emirate who knew :)
| 08.05.2020 17:05 | # 4 |
impact |
I was enough, but my fexzi brother clearly explained ..
| 08.05.2020 17:05 | # 5 |
Bumper download is really simple. Believe me, I am not at all familiar with these issues, and even after that, I removed the bumper and headlights within 30 minutes, observing the diagrams and information in the forum. However, if your headlights are your original headlights, you should know that you should not dismiss it. This will be the process that will take your real time :)
| 08.05.2020 17:05 | # 6 |
impact |
I cut off the walla one by one, but don't put it on your head .. I used a flat screwdriver to open the headlights. however, it may be useful to put it in a little hot water or leave it in the sun for a long time .. > I swept around the edges & nbsp; and cut the sticky material between & nbsp; falcatay and so on. Also, before painting the chrome inside the headlight, I definitely recommend sanding with fine sandpaper. Apart from that, I recommend you to use bright black in the headlight paint. Varya, if we were in the same city, it would be great if we worked together ..
| 08.05.2020 17:05 | # 7 |
fexzi |
It is not a difficult operation, as you said, you can handle it in 30-40 minutes. No problem.
| 08.05.2020 17:05 | # 8 |
impact |
We've set it up :) :) Apart from that, I used limescale remover for headlight cleaning, but I saw the benefit, but my intention was to sand the glass from inside, but obviously it didn't eat because it would be hard inside .. I also think of getting angel or something and changing it with the original headlight ..
| 08.05.2020 17:05 | # 9 |
My brother Emrah, if you are not satisfied with the angels, I would like you to keep in mind that he always has a request :)
| 08.05.2020 17:05 | # 10 |
impact |
[QUOTE = Gargi] If you are not happy with the angels, my brother Emrah, I would like you to keep in mind that she always has a request:) [/ QUOTE] |
| 08.05.2020 17:05 | # 11 |
friends, I want to paint inside the headlight, and one of the headlight has darkened from the outside. I can get hungry. Which product can I use? Which paint should I buy?
| 08.05.2020 17:05 | # 12 |
fexzi |
be included in the team, be aware of me :)
| 08.05.2020 17:05 | # 13 |
impact |
[QUOTE = fexzi] Let me know that I am involved in the team: / div>
| 08.05.2020 17:05 | # 14 |
impact |
[QUOTE = blinddark] friends, I want to paint inside the headlight, and one of the headlight was darkened from the outside, I can get hungry. if so, the problem is solved by sanding ..
| 08.05.2020 17:05 | # 15 |
impact |
bro, let's not junyan or anything lenses are good yaw .. darken you inside like a monster
| 08.05.2020 17:05 | # 16 |
fexzi |
I shared, I will support as much as I can in the How-To section.
| 08.05.2020 17:05 | # 17 |
In the 307 bursa, I brought my headlamps with an excess of my hand in order to evaluate my free time, & nbsp; I brought it to a friend and opened it with the help of a heat gun, and cleaned it and painted it with matte black paint and applied darker orange on the signals. Tomorrow I will take a picture of the headlights for you and at least create an idea in your mind.
| 08.05.2020 17:05 | # 18 |
fexzi |
[QUOTE = Gargi] In the 307 bursa, I brought my excess headlights to my friend with a heat gun and used it to clean up and darken it with a matte black paint. . Tomorrow, I will take a picture of the headlights for you, and at least create an idea in your mind. / div> Good bye.
| 08.05.2020 17:05 | # 19 |
impact |
[QUOTE = 307 bursa] [QUOTE = impact] bro, let's not junyan or something lenses are not good yaw .. use darken you like a monster [/ QUOTE] If you say so, I will give up directly, as you say, my master will do the best way to darken them. The easiest way to open the headlights is to make them stand in hot water. Emrah has made sense to me:)) < / div> I think there is no need for the original is more beautiful I think .. when it comes to hot water ; I have vectra, I had a headlight, it was broken, we opened it with a heat gun, I did not hurt at all and it was easy. / b> again, don't forget :) sand chrome places and use glossy black ..
| 08.05.2020 17:05 | # 20 |
impact |
[QUOTE = 307 bursa] hi friends, the process has ended at 5 pm, just to open the inside of the headlight, death and brother, be yourself, do not bother yourself, take a friend who will definitely help you, when the window of the headlight is detached, what the blessings have closed, but the victory of perseverance has taken care of it now. Let me tell you what I did, and help those who want to do it after that :) Friends told me how to disassemble the bumper and headlights. I think the easiest method to open the headlight is the heat gun ... I think it is easier if you become a hot water blower melting silicon 2 people. someone slowly separates the headlight, then clean it nicely, lightly sand the metallic part and apply the spray paint on the intervals, then we gently silicon it and tie the headlight around it with a cable tie, then we collect it and say good luck and have a good day We say use it ... mine was very good but wonder the pictures a little :) :)) soon ..... & nbsp; [/ QUOTE] scholarship where are the pictures? :) B> div>
