How to remove the 206 rearview mirror?
08.05.2020 14:10 # 1
Ozgur
How can I disassemble this interior mirror?
I did not want to force it because I could not be sure what side it was on.
08.05.2020 14:10 # 2
Ozgur
DID NOT TRY THEM?
08.05.2020 14:10 # 3
hasimayaz
Did your rearview mirrors fall prey to the white falcon terror .. or did the children of the neighborhood use the goalpost? Do not worry..
When we slightly pull the glass mirror, we can see the position inside. We pull a little harder and separate the mirror from the mechanism. We save the mirror from two iron rods.
That's how iron rods look inside. The nails we need to put up are shown in the picture
We take the nails back to their former position for reassembly
When we remove the mirror, two connectors of heating devices are waiting for us on the vehicle side. We remove the connectors without short circuits. Let's be very careful about what we get from where. even if we have sign paint at hand, let's mark it.
We need to remove 3 Torx10 screws. These screws are the screws of the adjustment equipment. Number 1 on the top.
and screw number 2
and screw number 3.
On the back of the connector, we are waiting for the electrical connector. we remove it with a thin flat screwdriver.
The top cover is attached to the main body with 3 tabs. But we have to do this process very carefully. The cover is very gentle. The same is true in the bottom cover. If we break the nails, we have no return. High attention
The rest of the body holds 4 Torx20 screws. One of the base
other
2 on the bottom
The main body can now be removed.
It's time for the rest of the trunk
If we want to paint the mirror completely or replace the temperature sensor, we must continue with the processes.
We remove the triangular cover on the side by removing it from its nails. High attention to tweeter calories.
We disassemble the connector.
We remove the 3 Torx20 screws. These screws hold the rest of the body
To remove the plastic parts, we need to remove the 2 screws at the bottom and the 2 screws inside.
The process is complete, we can now remove the mirror.
ALINTIDIR. (Turkish translate by Haşim Ayaz hasimayaz@gmail.com )
May it be easy for everyone.
08.05.2020 14:10 # 4
by_sertan
buddy, can we learn the purpose of dismantling?
08.05.2020 14:10 # 5
Can Duzyatan
[QUOTE = by_sertan] buddy, can we learn the purpose of dismantling? [/ QUOTE]
Free does this Sırıtma
In the car that will not leave any parts for the sata, Sırıtma
08.05.2020 14:10 # 6
Ozgur
I said the inner mirror, but ... I saw this from the forum already ..
I apologize for the inconvenience I have caused. Gülme
My darkening mirror swap Sırıtma
08.05.2020 14:10 # 7
hasimayaz
[QUOTE = uruk33] I said the inner mirror, but ... I already saw this from the forum ..
You don't have to disassemble anything. The mirror rail pushes firmly upwards from the rail.
08.05.2020 14:10 # 8
Ozgur
I understood the master, so many thanks.
08.05.2020 14:10 # 9
Ozgur
my master master came out when the mirror was pulled down. thanks again.
