How to remove the 206 ceiling lamp? |
| 08.05.2020 14:07 | # 1 |
| 08.05.2020 14:07 | # 2 |
![]() Gently separate it from the marked place with a thin flat screwdriver. |
| 08.05.2020 14:07 | # 3 |
I will disassemble it first ... should I open it from there first?
| 08.05.2020 14:07 | # 4 |
[QUOTE = uruk33] I will remove it completely ... should I open it first from there? first unscrew here then you will see the nails of white plastic inside. You cannot get rid of the electrical socket without removing this assembly first.
| 08.05.2020 14:07 | # 5 |
I understand.Thanks a lot ... I really liked it ... I dived directly from the sides. I did not break it twice.
| 08.05.2020 14:07 | # 6 |
individual |
Free, are you switching to submarine light? |
| 08.05.2020 14:07 | # 7 |
ERGİN YARDIMCI WHAT YOU SHOULD NOT BE .. :) I REMOVED THE CEILING LAMP.
| 08.05.2020 14:07 | # 8 |
[QUOTE = uruk33] WHY YOU WILL NOT BE AN ERGIN HELPER .. :) I REMOVED THE CEILING LAMP. I DID EXCEED IT IN A SOCKET? [/ QUOTE] It can be for sunroof control or rain sensor.
| 08.05.2020 14:07 | # 9 |
rain sensor already exists in my car .. in the headlight ... i don't understand it seriously
| 08.05.2020 14:07 | # 10 |
HRMNKY |
[QUOTE = uruk33] rain sensor already exists in my car .. in the headlight ... I don't understand it seriously [/ QUOTE] Not for the map lamp, brother? More cables come from all over this car. I dive into the submarine event, I hope I will get good results soon.
| 08.05.2020 14:07 | # 11 |
Will murat be: D
| 08.05.2020 14:07 | # 12 |
Are there any compatibility problems when installing the free map lamp? Can it be directly removed and attached to the submarine?
| 08.05.2020 14:07 | # 13 |
no. The original 206 map lamp. You won't have any problems. I bought the electricity from the ceiling lamp. I did not submarine because it is not the org.
| 08.05.2020 14:07 | # 14 |
I bought it from the one who has a map reading in the new bitane rc. I wrote it wrong, I guess I don't want to make submarine, I just bought the unit with map reading lamp on rc. Can I take the old one out and put the new one out? |
| 08.05.2020 14:07 | # 15 |
Brothers come easy, I removed the ceiling lamp. It was broken. I bought the frame for 90 TL. It just sat inside. I inserted a led bulb, but sometimes it cuts the light. Also, the LED in sleep mode.
| 08.05.2020 14:07 | # 16 |
sonerkyl |
[QUOTE] status [/ QUOTE] a situation related to the light bulb, I have a led, there is no problem. there is probably no chip because of that
| 08.05.2020 14:07 | # 17 |
So the leddemi chip should be
| 08.05.2020 14:07 | # 18 |
ALLEX |
[QUOTE = utku1927] Leddemi chip should be so [/ QUOTE] I bought Photun t10 bottomless led and directly attached it. It worked pretty well in our sws when the double ceiling lamp was on. I http://forum.peugeotturkey.com/forum_posts.asp?tıd=40868&kw=&title=hafta-sonu-icraatlar-modasina-uyduk-bakal |
