How to remove the 206 cassette player?
08.05.2020 15:04 # 1
albay32
friends, I need to remove my cassette player and insert a cd player.
08.05.2020 15:04 # 2
Kemanyak
Dude, if you can't find a pin (skewer), unscrew the cap above and release the sockets with your hand, it will come off easily.
08.05.2020 15:04 # 3
GiTaRRa
there are mm gaps on the right or left, there is a flat trowel style, just be thin, for example, it is in the hands of those who shoot the glass film, you can push it forward with a thin 3 cm width or something. You can remove the plug-in sockets in this system.
08.05.2020 15:04 # 4
albay32
I CANNOT FULLY UNDERSTAND THE POWER THAT SEK REMOVED A FRIEND SOMEONE IN THE FORUM WITH THE ELECTRICAL CABLE SER COPPER AND THROUGH THE KEY TO THE HOLES THROUGH THE KEY SELF BASSELY
08.05.2020 15:04 # 5
there is a thin bar like a special needle that women use for embroidery.
08.05.2020 15:04 # 6
slnysf
to remove it, put something like a stick in those holes and pull it towards each other (all four).
08.05.2020 15:04 # 7
Kemanyak
[QUOTE = albay32] I CAN'T FULLY UNDERSTAND THIS PEP REMOVE THOUGH THE FRIEND IN THE FORUM, SOMEONE WAS BROKEN KEY COPPER WITH THE ELECTRIC CABLE SER COPPER [/ QUOTE]
The cap of the cap with the four flasher and screen is the easiest to come out. Because you can easily remove it from the edge. you can already see the sockets from there. Appropriate thickness skewers will also work, but you will have to open both at the same time. You remove the cap and do your job comfortably.
08.05.2020 15:04 # 8
rifatseker
In this way, a spit or power cord or 4 thin screwdrivers will work as in the other picture.
[TUBE] skdg2pamx1m [/ TUBE]
rifatsek is 2011-02-01 15:20:21
08.05.2020 15:04 # 9
albay32
Thank you for your help, and thank you for your help.
08.05.2020 15:04 # 10
rifatseker
You're welcome.
08.05.2020 15:04 # 11
umiterkan
08.05.2020 15:04 # 12
umiterkan
A LITTLE HARD COPPER CABLE WORKS
WIRE THE CABLE FROM THE SOCKET SIDE
