how to remove sticky stains ??? (solved)
Homepage » PEUGEOT MODIFIED PLATFORM » How To
08.05.2020 18:20 # 1
[QUOTE = bitter] hi guys I had my white angel's bonnet guard in a very bad condition, even though it was very hard I removed it, but the sticky stain remained as it was. I'd try it;
solve fat
diesel
wd 40
That Smile
I tried these, but it doesn't work much. flood. I will try thinner gas oil and oil- free lining spray. I am waiting for the opinions of friends with other suggestions ... [/ QUOTE]
my only solution is the cellulosic thinner.
he tried all of them in a friend like you, but he made cellulosic thinner.
here it is. also wrote the result
http://forum.donanimhaber.com/m_48898187/tm.htm
maverick 2014-02-27 19:27:48
08.05.2020 18:20 # 2
tongucuk
pure alcohol or thinner is the definitive solution, but you can make it with alcohol if it does not come to plastic parts, but it does not harm the paint and plastic parts, alcohol makes matting the paint a little.
08.05.2020 18:20 # 3
Bugra
I previously solved the similar event by pressing hard with hot water and microfiber cloth, but ...
08.05.2020 18:20 # 4
furkanyakar
tanned water will also solve your job.
08.05.2020 18:20 # 5
Alicilik
[QUOTE = maverick] [QUOTE = bitter] hi guys I had my white angel's hood guard in a very bad condition, although it was very hard to remove it, but the sticky stain remained as it was. I'd try it;
solve fat
diesel
wd 40
That Smile
Is it cellulosic?
We use the plate paint to disassemble the paint of the body.
08.05.2020 18:20 # 6
Alicilik
I insist on clay: D
08.05.2020 18:20 # 7
[QUOTE = Blushing] [QUOTE = maverick] [QUOTE = bitter] hi friends, my white angel's hood guard was in very bad condition, although it was very hard to remove .. but the sticky stain remained as it is. I'd try it;
solve fat
diesel
wd 40
That Smile
Is it cellulosic?
I'm a liar of hardware Smile
A friend who has a similar problem has opened the subject and reached a conclusion. Didn't you look at the link I gave?
08.05.2020 18:20 # 8
koramiral
I had read somewhere for useful information, and the only thing that sticks these types of spots and Japanese glue was acetone.
08.05.2020 18:20 # 9
Adem Kurtuldu
I think your thinner solves your job after applying carefully with a cloth, I don't think it will be bey
08.05.2020 18:20 # 10
barishrocker
this is the product that is your medicine. I also used it to remove the hgs label on the glass. You wipe it with microfiber cloth and squeeze it ...
http://www.sanalpazar.com/atasresinol-recinezift-folyo-yapiskani-sokucu__isp7061213
barishrock is 2014-02-27 22:44:24
08.05.2020 18:20 # 11
tongucuk
Do you share a picture after you wipe it with acetone =)
I also did not personally use the product mentioned by peace, but I think it may damage the painted surface.
it is the only chemical alcohol with the probability of experiencing 0 problems .....
08.05.2020 18:20 # 12
acemi pecocu
Fotoğraf YWW If you have done something, please answer that you do not drag the nation wrong.
08.05.2020 18:20 # 13
scorpion_enis
With 0 number 3m paint sandpaper, watery sandpaper is removed from the adhesive on the clear mat, then the entire hood shines like paste polish. wd40 or something you will damage the trial paint. it works on cellulosic thinner, but don't hold the excessive damage on the paint. scorpion_enis 2014-02-28 00:55:46
08.05.2020 18:20 # 14
barishrocker
[QUOTE = 307bursa] [QUOTE = barishrocker] is the product of your medicine. I also used it to remove the hgs label on the glass. You wipe it with microfiber cloth and squeeze it ...
the guys have done it, we are still trying to get out with it :))))
doesn't that hurt the paint harm ???
I used this on the glass and wheels of the vehicle, it did not cause any problems, but I did not use it on the bodywork. At home, I applied it to the American door, but it did not remove the paint. I think that if the American did not damage the paint of the door, it will not give it to the car, but the most guaranteed is to send a message to virtue paint and ask.
08.05.2020 18:20 # 15
s.seckin
brother, cellulosic will not come out in the paint :) you can come out with alcohol while removing the hood, if you used a hair dryer :)
08.05.2020 18:20 # 16
Mustafa-almanya
In summer, the paper adhered to the plastic on the door with paper tapes, the tape said, let the tapes stop for 1 day. However, I do not remember whether the thinner said cellulosic one or not the cellulosic one. I took what he said and removed it with him. However, I already matted the paint with the methods I tried before. Then I polished that part of cake and returned to normal.
footnote: The car was black.
I'm glad you solved the problem, by the way,
08.05.2020 18:20 # 17
aremtu
Sa friends,
When I gave the car to the industry, the side of the master car poured something under the skirt, I think it was a paste. The output occurs when you wash the car. It dried out, did not come out when washing, it scratches the paint when scratched. What do you suggest?
08.05.2020 18:20 # 18
barishrocker
[QUOTE = aremtu] Sa friends,
a.selam .. there was a product called atas decabit, which removes bitumen stains. investigate it, maybe it will be a solution.
