How To Remove Peugeot 206 Rearview Mirror (Glass)?
08.05.2020 19:24 # 1
Viruse
Hi friends,
In the Forum there is a narration about the subject, but since the pictures are deleted on the site where the images are uploaded, not much is understood.
How To Remove The Rear View Mirror Glass Of My Peugeot 206 (2006 Model). If You Have Any Picture Expression About The Topic, I would like You Aid. Thanks in advance ...
08.05.2020 19:24 # 2
Alicilik
Docs Backup has told so much
08.05.2020 19:24 # 3
samet206
When I removed the mirrors to cover the foil, I wanted to remove the glass and extend the coating to the interior in order to give the original image. During this process all screws on the mirror were removed.
08.05.2020 19:24 # 4
I wonder if the outside temperature sensor can only be done by removing the glass.
08.05.2020 19:24 # 5
Viruse
[QUOTE = samet206] When I removed the mirrors to cover the foil, I wanted to remove the glass and extend the coating to the inside to give the original image. I don't know if the screws have anything to do with, but during this process all the screws on the mirror were removed.
I'll try it this way tomorrow. As you said otherwise, there is no wire in the back. Also, the mirror is very tight.
08.05.2020 19:24 # 6
Viruse
Whatever I tried did not happen. Is there any extinguisher or who sees the dismount :)
08.05.2020 19:24 # 7
teacher, take a look at the link I gave. Smile
I http://forum.peugeotturkey.com/forum_posts.asp?tıd=40868&title=hafta-sonu-icraatlar-modasina-uyduk-bakal
