How to remove peugeot 106 headlight? |
| • Homepage » PEUGEOT MODELS (FAULTS AND SOLUTIONS) » 106 | |
| 08.05.2020 16:05 | # 1 |
Burak07 |
| 08.05.2020 16:05 | # 2 |
You have to insert the bumper to insert the headlights when you lie under the vehicle, there are 2 screws on the left side and 3 on the right side.
| 08.05.2020 16:05 | # 3 |
Burak07 |
[QUOTE = psychoabi] You have to insert the bumper to insert the headlights. When you lie under the car, there are 2 screws on the left side and 3 on the right side. Is it that easy? |
| 08.05.2020 16:05 | # 4 |
speedark |
Unfortunately, you cannot remove the headlights without removing the bumper.
| 08.05.2020 16:05 | # 5 |
When you look under it, you see which screws hold the bumper, just stick it back.
| 08.05.2020 16:05 | # 6 |
Burak07 |
No, I couldn't do it, I was nervous, I just came, I have to go home to the electrician.
| 08.05.2020 16:05 | # 7 |
Is there any place you know that adjusts headlight for Angel headlights? no headlight engine. Are they disassembled too?
| 08.05.2020 16:05 | # 8 |
Burak07 |
no I guess it is not necessary to disassemble, cem brother had done it to his own vehicle, I think we need to get information from him |
| 08.05.2020 16:05 | # 9 |
[QUOTE = Burak07] I couldn't do it, I swear I was nervous, I just came, I have to go home to the electrician. [/ QUOTE] Did you fail to insert the bumper? What problem did you encounter? |
| 08.05.2020 16:05 | # 10 |
Burak07 |
[QUOTE = koliva] [QUOTE = Burak07] I couldn't do it, I swear I was nervous, I just came home, I have to go home to the electrician. [/ QUOTE] Did you fail to insert the bumper? What problem did you encounter? [/ QUOTE] yes, I couldn't remove the bumper. |
| 08.05.2020 16:05 | # 11 |
First of all, you need to open the hoods, the screws mentioned are under the hood this Saturday, I will take the pictures if I forget that I will remove the bumper;)
| 08.05.2020 16:05 | # 12 |
Burak07 |
[QUOTE = umitarmatli] first of all you need to open the hoods mentioned screws are under the hood this Saturday i will also take pictures if i forget that i will remove the bumper;) [/ QUOTE] I removed the hoods already but I couldn't see it is restricted when the car is a little low. My field of view is hopefully you can take the pictures in detail and understandably and share them. ![]() |
| 08.05.2020 16:05 | # 13 |
I hope that will be useful. The locations of the screws are shown in the figure. |
| 08.05.2020 16:05 | # 14 |
metin |
[QUOTE = Burak07] [QUOTE = umitarmatli] first of all you need to open the hoods mentioned screws are under the hood this Saturday i will also take the pictures if i forget i will remove the bumper;) [/ QUOTE] I removed the hoods already but I couldn't see it is restricted when the car is a little low. My field of view is hopefully you can take the pictures in detail and understandably and share them. ![]() [/ QUOTE] If you are restricted when the vehicle is low, you should take it to the jack and try it, but more work areas are created.
| 08.05.2020 16:05 | # 15 |
Could it not be visible from the mud? They are very stiff and mine was not visible from the mud when I first bought a screw in the screw.
| 08.05.2020 16:05 | # 16 |
mehmet eren |
I think if you are not crazy or experienced in this matter, I would say do not try it yourself.
| 08.05.2020 16:05 | # 17 |
speedark |
[QUOTE = mehmet eren] I think if you are not crazy and experienced about this, I would say do not do it yourself, my friend got the master [/ QUOTE] +1
| 08.05.2020 16:05 | # 18 |
I think you do not need to go to the master for a bumper that can be removed with a total of 5 pieces of 10-11, at least you will know your vehicle better;)
| 08.05.2020 16:05 | # 19 |
mehmet eren |
You say right, my friend, if I do not have experience, I told myself that I will not do it myself, I warn my friends like that.
| 08.05.2020 16:05 | # 20 |
you are right, but the mentioned work is not a detailed job, we give information about how to do it, not only does it or goes to the master but it is not a difficult job to go to the master. It is very simple to disassemble when there are 10-11 and 12-13 keys
