How To Remove Dried Sticker From Car Window?
08.05.2020 17:43 # 1
By_Akademisyen
The sticker of the peugeot service has been stuck on the rear window of my car, and it has been stuck for 5-6 years, and now it has solidified, some of it has been removed, but some of it remains firmly attached. How can I get it out?
08.05.2020 17:43 # 2
samet206
I cleaned the double-sided tapes (stains and marks on the plates) with rubbing alcohol on the plates, it was like zero.
08.05.2020 17:43 # 3
KenBlockJR
I scrapped it with permatik so I kenblockj is 2013-06-21 22:08:56
08.05.2020 17:43 # 4
blinddark
Make a sparkling water with a dishwashing detergent and a glass of foam water, then, with the help of the glass with plenty of water, do not think that there is no film on the glass of the excavation.
08.05.2020 17:43 # 5
mami202
Feed the cellulosic thinner to the sticker area with the help of a cloth and it will be very comfortable and cleaned.
08.05.2020 17:43 # 6
tongucuk
Just watch out for my thinner teacher resistance, but
08.05.2020 17:43 # 7
Alicilik
Whether window film or sticker, they love alcoholic water and immediately release themselves. Spray the pure alcohol diluted with water so that it affects the edges in a sufficient amount.
08.05.2020 17:43 # 8
spearo
cellulosic thinner ;)
08.05.2020 17:43 # 9
bysarsinti
Come off with a hot water scrub, sir. Do not deal with thinner gas and brush, cut the window film ...
08.05.2020 17:43 # 10
peugeotttt
Wipe the glass frequently, then scrape it with a razor.
08.05.2020 17:43 # 11
konyali42
Do not worry, I think you can heat your blow dryer well then remove it easily even with the help of nails. I always do so. The result is perfect.
08.05.2020 17:43 # 12
By_Akademisyen
As you mentioned, I spilled the stick with a razor, I scratched some of the red strips on the rear window, 1cm or so, and it seems like it broke very little ??
08.05.2020 17:43 # 13
voodoo
I hope that it is not the resistances in the rear window that you call red ribbon. And I hope it is not broken
08.05.2020 17:43 # 14
By_Akademisyen
I think the red horizontal lines on the rear window are resistances. But some of the lines were damaged. 1 -2 cm or something. Would this be a problem?
08.05.2020 17:43 # 15
GokhaN
that resistance is canceled, that part does not work.
Since the rear glass is risky, the sticker should be removed by heating it. If there was no heat gun, it should have been left under the sun and then removed, and the rest should have been wiped with alcohol.
