How To Remove 307 Water Radiator (Urgent !!!)
08.05.2020 17:01 # 1
tolga35
& nbsp; greetings; there is a slight leak under the water radiator
I want to do it myself but I couldn't disassemble the radiator
I'm waiting for your help, especially if it is illustrated
thanks in advance ...
08.05.2020 17:01 # 2
It's a simple process, but it changes according to your vehicle model. Let me write it sketchy, you go and have a look and practice.
The radiator holds 2 screws. 4 hoses are connected. The screws are located at the top of the radiator, i.e. on the bumper side. If the screws are as in the picture below, we remove the two plastic clips that appear and try to reach the screw from below, next to the bonnet lock mechanism, by gently flexing. Assuming that you can remove it, you insert the 4 hose clips connected to the radiator by opening the clips. Then you push the radiator to the motor side and pull it upwards.
In older models, this is not easy and the bumper may need to be lowered. Take a look, take the photo here. Easy to come.
08.05.2020 17:01 # 3
tolga35
again koliva, again help ...
just as you said, my brother, health brothers
thank you ...
08.05.2020 17:01 # 4
[QUOTE = tolga35]
thank you ...
[/ QUOTE] < br>
Thank you. +1 reward, I have more ways more & nbsp; "T
