|   | How to open the peugeot 307 hood from the outside |
| 08.05.2020 21:07 | # 1 |
|  emresensoy307 | |
| 08.05.2020 21:07 | # 2 |
|  GokhaN | |
Normally the hood will not open from the outside, you will damage both the hood and the lock if you force it out.
| 08.05.2020 21:07 | # 3 |
|  27BEN80 | |
squeeze oil or v40 into the keyhole, which is hard to open from the hood, there is nothing to do, try to find a solution from the player
| 08.05.2020 21:07 | # 4 |
|  emresensoy307 | |
by the way, the van
| 08.05.2020 21:07 | # 5 |
|  Gokcesel | |
[QUOTE = emresensoy307] friends locked the doors of my vehicle in the evening of my car, but the license plate lamps did not go out, then I locked the doors from the remote without removing the battery terminal, then I removed the polar head, after a day, I inserted the key to open the door and the key did not turn. I am thinking of opening the hood from the outside. [/ QUOTE]  Turkey has Facebook`ta Peugeot 307 page teacher can learn from there I have had ideo sharing. A friend intervened under the vehicle and opened it without damaging the hood .. | |
| 08.05.2020 21:07 | # 6 |
|  deneme51 | |
With 20 cm iron profile, you can easily open from the outside, but you should use a flashlight.
| 08.05.2020 21:07 | # 7 |
|  Orcun.Dmr | |
If you want to install the pole of the pole, you can lift the vehicle with a jack and enter it under it.
| 08.05.2020 21:07 | # 8 |
|  emresensoy307 | |
I did it, I opened the door to the locksmith friends
| 08.05.2020 21:07 | # 9 |
|  27BEN80 | |
Get well soon
| 08.05.2020 21:07 | # 10 |
|  sonerkyl | |
Get well soon.
| 08.05.2020 21:07 | # 11 |
|  ersin61 | |
Get well soon ...
