How to Make Paste Emery Paint?
Homepage » PEUGEOT MODIFIED PLATFORM » How To
08.05.2020 17:26 # 1
werty
Hello friends,
As it is understood from the subject, I decided to repair the scratches on the bumpers in my car. Considering the immersion =)
I need your vast experience and guidance,
As I learned, the paste and hardener are mixed together and applied to the damaged area. After it dries, it should be made to the armor, but how many sandpaper is used and when it is wet it does not know.
When it comes to painting, how to make it as a local paint. and after applying the paint, varnish should be applied.
Thank you very much for your help.
08.05.2020 17:26 # 2
I was just looking at this topic the day before. There is some damage in my vehicle too, I shared the pictures in the forum. I wonder if I can do it myself. After looking at the videos, I can say why not, but I need a closed place so I don't have it at the moment :)
I just need a lot of material :)
Just two videos is enough, already the other videos:
[TUBE] KuB6chd702E [/ TUBE]
[TUBE] hl5UG4GwcEk [/ TUBE]
koliva 2013-03-16 14:43:19
08.05.2020 17:26 # 3
werty
saol koliva Very descriptive videos. It was useful to me. I say it will be around 50 - 60 TL but I do not know the net prices at all. First, I start with the bumpers, I do some practice, I gain the habit, and I look at it. =) If I do not succeed, I will throw the pictures in the body shop: D
Let the weather get a little better and share the developments here.
08.05.2020 17:26 # 4
oguzhan29
thanks for sharing.
08.05.2020 17:26 # 5
TayfunGti
My friend, first of all, put the paste to the spatula, you can mix the hardener with a dull mixture, then dry it, then sand it with a thick sandpaper 80, then you can sand the first layer of it, then take another layer of paste and sand it with a fine sandpaper. You can add a little paint and mix it, and then you can make it work with watery 360.
08.05.2020 17:26 # 6
tongucuk
frankly, I trust myself in this kind of work, and I have a small place when I have done it. If I had a closed place and time, I would try to do my own work.
08.05.2020 17:26 # 7
IBRAHIM ASIL
Do not be afraid of my master, I did the local bumper of our fluence local (regional) it was so beautiful I bought the material more than 70 tl varnish, you need to apply varnish, it stops matte paint sanding, take a black, red sand, take a black la cone, do fine work with red, keep it in mind There is the glue of the gold from the place where you take the paint, the liquid is bsy brushing, before you paint, you paint it without sanding etc .. If you do not grasp, then we are waiting for the picture :)
