How to make a 307 speaker connection?
08.05.2020 19:38 # 1
dagdelen34
Hi friends, I bought a new hoporlor to the front and back of the 307, but the speaker and the connecting cable on the vehicle are just like plug plugs, it is simple, but the received speaker is different (different from the cable of the car). Thanks for the interested friends.
08.05.2020 19:38 # 2
samet206
Original speakers are like that because they are plugged in. The new speaker you have has a cable. But if you find a suitable socket for the socket from the vehicle and adapt it, it will be original.
08.05.2020 19:38 # 3
dagdelen34
There will be one more srum Insha'Allah, one of the cables I will make connection is red, one is gray and two are different, both of them are different, both of them are not as if there is a difference, as if it was gray + red negative, I would be pleased if you could give information on this issue, I would like to know if I am wrong, I did not know my red + `Thank you for the friends who answered.
There is a gray line like the same color yellow on the cables in the back door if you can give an idea. dağdelen34 2016-02-12 18:26:31
08.05.2020 19:38 # 4
samet206
The minus and the plus of the speaker is already clear. If there is no line or mark on the cables coming from the car, it should be possible to reverse the connection of the cables by replacing them, but if you connect it, you will not get bass sounds. basically the cable with a line on it comes out - I connected it in this way, everybody says the wrong line cable is positive, but there is no such thing. Sounds a quieter sound, so experimenting without exaggerating is the most definitive solution.
08.05.2020 19:38 # 5
dagdelen34
Thanks
08.05.2020 19:38 # 6
Alicilik
If there is no multimeter, buy a 2mt cable. One end to the + pole of the battery. The Context. Connect the other end to the parking bulb. Touch the other end of the bulb to the cables coming to the speaker. It is the minus that burns the light.
You can use this method to connect the cable to the negative part and use it in the fuse control.
08.05.2020 19:38 # 7
dagdelen34
Thank you
