How to disassemble the control handle?
08.05.2020 16:56 # 1
ahmetismet
Friends did not find it in the forum.
& nbsp;
How to remove the tape control lever under the steering wheel, can I do it myself? Must I disassemble the steering wheel? The glass control buttons were not pressing, I dismantled them, I cleaned them, now they are working super. div>
08.05.2020 16:56 # 2
Serkan
Dude, you will just unscrew the cover under the steering wheel, bend down and you will see the screws, then it is very easy to unscrew the lever and pull on the nail.
08.05.2020 16:56 # 3
ahmetismet
Thanks. I will try, if I can't, I will hurt again ..
08.05.2020 16:56 # 4
elestern
my teacher, he's not playing the 3 arms up and down, he's just fixed, the keys are just pressed & nbsp;
& nbsp; this way his function is
& nbsp; say I'm wrong & nbsp;
08.05.2020 16:56 # 5
Serkan
The radio joystick of the vehicle in his signature is as in the picture below
08.05.2020 16:56 # 6
Alicilik
If I remember correctly, there are 25 torque screws, two in the box right under the steering wheel. How to remove the vias and gently remove them. Pull gently on the arm. The arm is fixed. Just press the 5 keys on it and one scrollvar is rotating.
08.05.2020 16:56 # 7
elestern
If it is fixed, I will remove the little arm from my brother.
08.05.2020 16:56 # 8
Serkan
If [QUOTE = elestern] is fixed, my brother is going to take off the little arm, pioner mvh1400ub, and I will take it together and the brain part will work on me. ]
Where are you going to hold this lever in your vehicle
08.05.2020 16:56 # 9
elestern
I shouldn't have a small arm in my hand & nbsp; but I fix it somewhere we don't have a cure
08.05.2020 16:56 # 10
Alicilik
[QUOTE = elestern] shouldn't be there, there is a small arm in my mind & nbsp; but I fix it somewhere, we don't have a cure
A very convenient and original solution. No problem wasted trying. You don't need to get the handle zero. 5-10tl fln. It would be better if you gave 100 TL to the Pioneer class and searched for it. If you succeed in this event and share the stages here with a picture and a beautiful narration, you might see the smurfs one day "LOL"
Alliance 2012-07-31 01:32:39
08.05.2020 16:56 # 11
elestern
I got the confirmation of the folks, kipada 160 tle zero interest 12 installments how cheap and logical it came from a lot of places I got the arm in the queue. I think the arm will only happen when it interferes with the radio & nbsp; I will try now there are arm in the line, the publishers will look & nbsp; nowi & nbsp;
08.05.2020 16:56 # 12
elestern
By the way, the car in your car is 207, and you can control the control from the remote. >
08.05.2020 16:56 # 13
Alicilik
[QUOTE = elestern] Meanwhile, the car in your car is 207 and you can control the control from the remote & nbsp; I saw a video in the name of the guy who was putting it together and adding a piece in the name of the person who added it, you need to connect to the brain or something.
Avoid the imitations my only scam is "Wink"
That video is not my car 207 206 + & nbsp;
May your tape be good. The piece I bought came from abroad and cost me 100 TL. You just plug the cable into the tape and attach it to the tape.
You would have seen the forum a bit.
This is the main point:
http://forum.peugeotturkey.com/forum_posts.asp?TID=17977&KW=9350&title=direksiyon- my controller
(my guests on the last page: D)
http://forum.peugeotturkey.com/forum_posts.asp?TID=13452&KW=stalk&title=direksiyondan-k Remote-iin -Stalin-adapter
http://forum.peugeotturkey.com/forum_posts.asp?tıd=22818&kw=9350&title=mzik-sistemi-tavsiye
