How to connect the amphitheater? |
| • Homepage » PEUGEOT MODIFIED PLATFORM » Peugeot Sound Systems | |
| 08.05.2020 17:24 | # 1 |
EnSoNiQ |
| 08.05.2020 17:24 | # 2 |
Alicilik |
Sir, be very careful. If it chases from a small place, you can seriously damage the vehicle. I wish you were taking a photo. We could help in more detail. Ensure that the cables are touching both ends and that the cable is not broken-cut-broken. Does the wire harness come in contact with the chassis of the vehicle where you received the chassis? When it comes to the painted part, it may not come into contact. Pay attention to the remote end of the tape. Perhaps there may be a lack of tip at the tip. Attach one more cable to the place where you plug the cable from the battery, connect the other end of that cable to the input marked remote, and the amplifier should work. If it does not work even then, either there is a contactlessness in other cables or & nbsp; There is also a problem in the amp. |
| 08.05.2020 17:24 | # 3 |
master, i think you can get this job done to someone who is professional or if you have a tendency, you should be very careful. |
| 08.05.2020 17:24 | # 4 |
EnSoNiQ |
teacher, there was paint in the part where I connected the gndyi there could be no broken cuts, I carefully removed the floors and a thick cable I even cut it with a side chisel I will try again tomorrow - there is a problem in the place where I bought it. So how can I measure if there is electricity in the cable? I got insurance, could there be a problem in it |
| 08.05.2020 17:24 | # 5 |
Alicilik |
If you don't have a current olcer, find a bulb to work with 12v (if it is led, pay attention to the `` + `` - ''. Touch the ends of this light bulb to the wires you pull from the amp. It should be lit. I under the vehicle When I need it or when I need illumination in the back, it is good to be able to vbag the light bulb that comes to the amphitheater. But I repeat it. Notice. It burned to a tape that we met a short while ago. otherwise he is pertti |
| 08.05.2020 17:24 | # 6 |
EnSoNiQ |
thank you, there is no scratch, etc. let's see tomorrow I will try to have a led with it.
| 08.05.2020 17:24 | # 7 |
EnSoNiQ |
Guys, I bought the sound properly today and it worked but it sounds like a cizzzz in the sound.
| 08.05.2020 17:24 | # 8 |
Alicilik |
[QUOTE = EnSoNiQ] Guys I picked up the sound properly and it worked, but it sounds so loud that it sounds like cizzzz. Does the sound continue when you insert the Rca? |
| 08.05.2020 17:24 | # 9 |
EnSoNiQ |
There is no fan in the amphitheater. |
| 08.05.2020 17:24 | # 10 |
EnSoNiQ |
The sound that goes into the RCA disappears, why do you think that when I press the gas, there is a slight engine noise |
| 08.05.2020 17:24 | # 11 |
Alicilik |
[QUOTE = EnSoNiQ] The sound that turns on the RCA disappears, why do you think when I press the gas, the engine sounds lightly [/ QUOTE] RCA cables are troubled teacher. There are two solutions: 1-Replacing with a quality RCA cable (I prefer a silicone-based branded product) 2-To connect the existing RCA to the amplifier from the chassis (-) that you connect to the amplifier. When you do one of these, the problem will be solved & nbsp; Reviews |
| 08.05.2020 17:24 | # 12 |
EnSoNiQ |
I just bought the teacher instructors silicone style and thick 2 goes separately 2-To connect the existing RCAs to the chassis (-) you connect to the amplifier. How can I do this? I read a text and said, do not take the rca from the same place with the cable coming from different battery? I bought the brand as a set in the picture bertone & nbsp; div> |
| 08.05.2020 17:24 | # 13 |
Alicilik |
The incident mentioned is correct. I installed the system myself, but I researched it before. I passed the power cable driver RCA (3) by the passenger. How are you doing? There are noise-removing devices for this sound but it decreases the sound quality. If you say I will compromise this (this quality decline is not so much, but it draws attention in advanced systems only), you can take this product and use it by bridging the amp and RCA. For this, you need to go to the audio system or auto electrician. They will help them. / detail [/ link] "Quote ....... For about 5 years, I have been dealing with auto voices and voiceover work. I help the friend who wants it as much as I can. In paris incident, almost 7 of the 10 vehicles I do have a parasitic incident changes from vehicle to vehicle. If you ask, it is boiling from the car's dynamo, this is simple, and anyone can do it easily. The outer side of the jacks is already chassis, it can wrap the cable tightly there and hold it with cloth tape If it does not go through this process or if it does not go through the anti-parasite, find the chassis (-) of the tape and connect the RCA output jacks, and do not pass the signal cable from the same place when pulling the electrical cable and the signal cable under the laths of the right door. do it from the left door "
| 08.05.2020 17:24 | # 14 |
EnSoNiQ |
Thank you, I probably got it from the same place, so I hope that I will change places tomorrow.
| 08.05.2020 17:24 | # 15 |
Alicilik |
[QUOTE = EnSoNiQ] thank you I have had the same place, I hope you will change their places tomorrow. I did:) [/ QUOTE] You're welcome. I am happy if I could help. Be careful, these are not serious things |
| 08.05.2020 17:24 | # 16 |
EnSoNiQ |
:) Let's see, I hope I will be successful, I am careful about this business.
| 08.05.2020 17:24 | # 17 |
307 of a friend's electricity (+) from the battery was not soundproof, making the chassis and burning the vehicle completely, it would make more sense to do it with an experienced person.
| 08.05.2020 17:24 | # 18 |
EnSoNiQ |
My teacher insulation is no problem. I had a very thick and solid cable. I even wanted to cut the cable with a side cutter. Experienced people do not do very different things. My teacher passes the cable neatly. I made it myself, not afraid, and I succeeded now I will take the RCA cables on the passenger side, I hope it will be solved in the problem of light sizing :)
| 08.05.2020 17:24 | # 19 |
EnSoNiQ |
My brother Ali did the same as you said the parasite did not cut, but would you suggest something else the same? I relocated the cable.
| 08.05.2020 17:24 | # 20 |
Alicilik |
[QUOTE = EnSoNiQ] Ali bro, the parasite did not interrupt, I did as you said, but would you suggest something else the same? > But there is no guarantee that it will be the definitive solution. It is normal to see such things in electronic devices. Since the RCAs carry signals, all the electrical equipment in the environment creates an electric field, which is why it affects. High school 3 is the subject of electricity but the current passing through the cable is due to the electric field |
