how to cancel the malfunction lamp
08.05.2020 19:21 # 1
lead38
malfunction lamp lights up, is there any way to cancel?
08.05.2020 19:21 # 2
eeccaa
Isn't the best way to fix the malfunction? Obviously there is a stubborn malfunction. But a lamp that does not light up on any other fault will cause more trouble for you in the future.
08.05.2020 19:21 # 3
ismailkaya
(something happens like heart surgery ...) the sensors send command to the continuous brain rich-balances the mixture of the injectors injectors spray it accordingly
08.05.2020 19:21 # 4
lead38
It is not so, how many times these peugeots are getting moisture from the air is connected to the computer in the service. The throttle says it is being calibrated again. The lamp lights up again. This light is not about fuel, I always get po gas from the same place. I do not understand this peugot.
08.05.2020 19:21 # 5
Efe-Pojo
that light is all about the quality of a single fuel. lights when it exceeds the values specified in any sensor. Catalytic failure sometimes causes it to flash, sometimes it goes off, and this way, for example, and when it is lit, it gives antipollution warning on the screen, you have to look at what it gives.
08.05.2020 19:21 # 6
vpro
You remove the bulb from the indicator
Pejo gushes in the rain because the air filter draws water, let's fix it if anyone knows where it draws :) vPro 2015-07-05 11:48:56
08.05.2020 19:21 # 7
lead38
this warning means
`` I pollute the environment ''
either the catalyst is defective / clogged
either the petrol or diesel filter is dirty
or lambda sensor is broken
or instant gasoline
Buy gasoline or diesel oil from gasoline you trust.
fill the tank.
If the warning is gone after filling,
if it is still there may be the first 3 items
08.05.2020 19:21 # 8
themurat54
The friend is right, sometimes I wipe it, then I wipe it out, usually when I remove the air filter, it goes off when I use it a bit.
