How to adjust the Pejo 206 torsion
08.05.2020 15:27 # 1
fahrikem
Pejo 206, I want to drop the torsion and torsion of the previous owner. I called the master in Kutahya on the weekend. One of the masters mentioned that the rear axle's torsion shaft should be removed to do this job. what was done I thought it was dropped by simply adjusting the torsion after the wheels were removed. the albaydemirc 2011-05-25 20:48:41
08.05.2020 15:27 # 2
I think he thought the master balls could be broken. Easy to download after all the parts are intact. There is no need to insert arms anyway ...
08.05.2020 15:27 # 3
fahrikem
I reduced the torsion to 100 TL, so this price is normal
08.05.2020 15:27 # 4
[QUOTE = fahrikem] I reduced the torsion to 100 TL, so this price is normal [/ QUOTE]
Let us tell you what is done for 100 TL :))
08.05.2020 15:27 # 5
Mesut
I had a pedestrian for 80 TL and I took torsion :)) The process was also very pressed :) I took the wheels, stuck the cols, slid the teeth, gathered the back, did not take the 15 minutes torsion :)) good luck pasha :))
08.05.2020 15:27 # 6
axi206
I want to raise it a little bit too. If I ask anyone, he said that it would be too expensive to handle. That's why I didn't handle it. the car will take over. officially not working in the back amorsaor.
08.05.2020 15:27 # 7
Muhammet CAKIR
What did you do, my brother, I downloaded my 100 tlye motor, I wish I had consulted me first, I had 40 tlye springs, I was going to lower the torsions in 40 tlye.
08.05.2020 15:27 # 8
eren8er
anyway it is finished now .. good luck ... hopefully it has been the way you want ..
08.05.2020 15:27 # 9
mehmet_ers_07
08.05.2020 15:27 # 10
mehmet_ers_07
FRIENDS VALLA B
I WILL MAKE THE BEST BACK 25 TL HOW PRICE: D
