how to adjust peugeot 307 screen clock
08.05.2020 15:01 # 1
arslanbey01
friends do not know how to adjust the peugeot 307 min display time, i would appreciate if you help. thanks in advance. =)
08.05.2020 15:01 # 2
Ozgur
press and hold the button on the left.The cursor starts flashing.
Then set it with the other button. You'll find it is very easy.
08.05.2020 15:01 # 3
xMEGANx
MENU / Optinos / From there we write and write date or something in English and do it
08.05.2020 15:01 # 4
burakdmr
Is it not possible for me to do the original tepy in the vehicle without turning it off: SS
08.05.2020 15:01 # 5
Haksen016
If the car is old case, you will do as the friend said above, I don't know the 2006 make-up case.
08.05.2020 15:01 # 6
burakdmr
make up case: S
08.05.2020 15:01 # 7
burakdmr
When the battery came out after the tube, my time and date setting was broken. Is the former owner canceled the original tape, is not made from anywhere other than the tape this setting: SS 2007 model vehicle
08.05.2020 15:01 # 8
ADM
I have a make-up on me but if the original tape is canceled, do you know if it should be done?
08.05.2020 15:01 # 9
[QUOTE = basistrakrak] When the battery comes out after the tube, my time and date setting has deteriorated. Is the former owner canceled the original tape but is not made from anywhere other than the tape this setting: SS 2007 model vehicle [/ QUOTE]
my friend, you will press the button on the left of the road info screen continuously and when the time is set, the clock starts to blink.
08.05.2020 15:01 # 10
burakdmr
the clock is always flashing anyway ... well, it didn't happen, what do you mean by the button on the right, my friend ..: S: S
08.05.2020 15:01 # 11
ADM
there is a button on the left :)
08.05.2020 15:01 # 12
burakdmr
no or i couldn't find it :)) .. best I got them done when i went to service
08.05.2020 15:01 # 13
burakdmr
or how do I activate the old tape: S
08.05.2020 15:01 # 14
Sayoka
If you have the old tape recorder in your hand, you will wear it and you will adjust it on it ...
08.05.2020 15:01 # 15
zeynep taylan
How is the time and date set in make-up cases that no one has written yet?
08.05.2020 15:01 # 16
IsmailmiAbi?
actual
08.05.2020 15:01 # 17
dream
[QUOTE = zeynep taylan] still no one wrote how to set the time and date in make-up cases? [/ QUOTE]
It is easy if the original tapes were removed without cutting the original sockets while canceling. You can attach the original tape that you currently use without attaching an original tape and adjusting it with the menu button on the radio and cutting the electricity off.
Velev that; If the socket is cut out, the job will be long and thankful. If you don't have an electronic friend you know very well, nobody will bother (especially the service doesn't bother at all)
but if it is properly adjusted and installed nicely, you can even use the steering lever on the steering wheel.
Good luck with.
08.05.2020 15:01 # 18
qqyyxx
Sorry, but don't you trust the writings of the responding friends at all. They stated that the date, etc. settings can be made from the menu button on the original tape. In models before 2006, it is done by the button next to the screen.
