How to adjust 2004 307 dipped beam headlights
Homepage » PEUGEOT MODIFIED PLATFORM » 307
08.05.2020 15:10 # 1
inceyasar
Greetings friends After replacing the headlight of the 2004 model 1.4 hdi 307, I realized that the side I am replacing is overlooking. I looked at the adjustment points on the headlight, there is an adjustment screw that can be turned with an allen wrench, but it is used to adjust the lengths, but does anyone know how to adjust the dipped headlights?
08.05.2020 15:10 # 2
In accordance with the forum rules, you must first introduce yourself in detail.
08.05.2020 15:10 # 3
inceyasar
1- Your name and surname: Yaşar İnce
2.- Your age: 29
3.- Your vehicle (Brand, model): 2004 307 1.4 HDI XR
4.- Your Hobbies: -
5.- Your profession: -
6.- Where did you hear the site: From the Internet
7.- Your Blood Group: A +
8.- Your horoscope: -
9.- The team you support: BJK
10.- Which county or province are you in: Ankara
11.- Your MSN address: -
Nice to to meet you...
08.05.2020 15:10 # 4
inceyasar
Now that you have an idea, how do you get an idea of how your headlights are adjusted?
08.05.2020 15:10 # 5
Let's welcome you first. As far as I know, the mirrors of the headlights should not be separate from each other. Besides, short and long lengths are not adjusted separately. In general, there are 2 settings in the headlamps, one of which is downward and right and left. For example, in my car, there is a place that is adjusted with allen on the headlight height adjustment engine. when it moves there the setting changes. it is very simple. If you already told about it. As you are saying, it shouldn't be apart. headlight mirrors are one piece ...
08.05.2020 15:10 # 6
inceyasar
We're [I'm] glad to be here;
My teacher is just playing up and down, when I make adjustments with the Allen, there is no change in short, what do you say to this?
08.05.2020 15:10 # 7
I do not have detailed information about the headlights of the 307s, but it came to me as well :))
Friends who have tampered with 307 will reply.
08.05.2020 15:10 # 8
inceyasar
apparently we will stop by the industry at a convenient time
thanks anyway
08.05.2020 15:10 # 9
metin
If you look carefully, behind the highs, there may be the adjustment of the high beams, behind the lows the adjustment for the low beams.
the shorts can also be on the headlight adjustment engine.
08.05.2020 15:10 # 10
inceyasar
friends, the problem is solved, the problem is in the light bulb
as you say in the adjustment place, thanks to your help for the help of using the allen key with the screw on the headlight
08.05.2020 15:10 # 11
It would be very difficult to adjust the headlight if the short and long settings were different, as you said. 2 mirrors are fixed to each other. When the headlight adjustment motor moves, both will change.
08.05.2020 15:10 # 12
tufan31
I just set it up. (For the old safe 2002 307)
Up-down adjustment; both long and short are set both. When you open the hood and look at the headlamp from above, the white all-in entry appears just above the main beam. There is also a star screwdriver slot, you can also adjust it with a star screwdriver.
Right to left adjustment; when you open the dipped headlight cover , it looks like a stick with a flat screwdriver entry on the fenders side. By inserting a flat screwdriver into the slot in the head of this bar, headlight is adjusted to which side you turn. Sırıtma
