HOW TO ACCELERATE THE BEST? WHAT ARE THE ADVANTAGES IN THE RACES
Homepage » PEUGEOT MODIFIED PLATFORM » Useful Documents
08.05.2020 17:32 # 1
Memed8572
For some, racing is passion, excitement. Even the races of the bird series can excite some. I write this article for those who carry that excitement and want to improve their technique. Peugeot players should always be one step ahead :)
In this type of races, the car wins the race. But the effect of the driver is undeniable. You have to push the boundaries, if you say that I can pass my speed and pass my name with a slow vehicle.
Let's start with the first departure. For the first take-off, move the vehicle to a speed slightly higher than the maximum torque speed. At the moment of take-off, pull the clutch just enough to skid as much as possible. But do not try to get up without skidding. In this way, high compression is provided in the engine and this gives you an advantage of several km / h at the first start. Even if your car falls on skidding, do not pull it out of the gas, it can deceive you by coming to the circuit breaker. If the skid is spinning, wait for the skidding to end, change your gear without pulling your foot from the gas to the end, and do not be skidded to the revolver, you will lose time, leave the clutch hard when the gear is raised. (Note: This situation damages the clutch balls. We will always do this technique when changing gears. Changing gear is very important. For example, for my vehicle, which gives its maximum power at 5700 rpm, while shifting at 6500 in 1st gear, how much should the throttle be pressed? This is the second criterion, if your vehicle is If it sets electronically, you can root the gas pressure, but otherwise it's up to your experience. But don't rotate the gas tool unintentionally. Give as much gas as possible. Let's talk a little bit about the wind tunnel. If your race has been long and you have climbed up to speeds such as 160-180, you can get right behind the vehicle in front and gain speed there. This resistance is so high that wind resistance is exactly as much as your engine can produce at the full speed of your vehicle's factory data. The car with a top speed of 200 km / h can easily find 210 km / h behind another vehicle.
The things that can be done ethically are listed above, let's come to the unethical.
Take off weight; It is a good strategy to remove the spare tire, especially the excessive weights in your vehicle, not to take other people to your vehicle, to keep the gasoline at the lower level. I have such hurt.
Not competing with the cold engine, driving the vehicle at high speed until it goes to the race area, both temporarily cleans the engine, brings the oil to the ideal consistency and prepares your vehicle for the race.
So how much does this last article save you? If 0-100 10 seconds for a 1000 kg vehicle, 100 kg excess weight means 1 second loss. This corresponds to approximately 2 vehicle lengths at a speed of 100 km / h. This is a good advantage for equivalent vehicles.
It is your responsibility to try what I wrote. It is written for information purposes only.
08.05.2020 17:32 # 2
Barut
Thanks for the information, it will help me a lot.
08.05.2020 17:32 # 3
elsoberano
thanks for sharing Clap
08.05.2020 17:32 # 4
plawert
You are a mechanic, let's know where we are, let's do these moves around
08.05.2020 17:32 # 5
Memed8572
I hope you will find useful information.
08.05.2020 17:32 # 6
candanxyz
Beautiful.
08.05.2020 17:32 # 7
mstf shn
thanks....
