How should pego 306 treatments be?
08.05.2020 16:25 # 1
turcomemo
Hello everyone, yesterday I bought 97 model pego 306 xr 1.8 engine cars from auto market yesterday. The car officially fell in love with the start-ups and handling, but I was stuck on some issues. The power steering is very hard (winter tires do not know, I do not know) the lights of the speed instrument panel are very faint. . I want to change the oil and water, how much will their total cost cost me. I'll take my service in Ankara, or is there any beautiful pego master you know. (I can not pass this without saying that, as someone who gets 1.3 motor vehicles for years, it is an incredible pleasure for people to skip 2010 model cars on departures and still want to shift on the ramp)
08.05.2020 16:25 # 2
Ucyuzalti
I use castrol as oil. I recommend it in my own vehicle. Beautiful oil. Winter has come. Have your antifreeze measured. # 111; n "/>
Air filter, throttle, spark plug, spark plug cables affect fuel and performance very much. If the filter is dirty, fasten or replace air. check the level of your vehicle's steering fluid, & nbsp; If you wear a bidet case, the reason for turning more comfortably increases the distance to the center momentum, ie "Wink"
08.05.2020 16:25 # 3
turcomemo
The prices I received from a private master in Ankara today asked for 150 liras that would replace
in winter maintenance (oil + oil filter + air filter). after all, castrol makes 75 lira if using oil, oil filter 15 and air filter 15 makes 105 if you think 150 is not too much for workmanship?
08.05.2020 16:25 # 4
Ucyuzalti
Makes up to 100 TL & nbsp; All of them, never mind the master, go to the normal oiler, change the oil. buy the air filter, you can install it yourself something simple ÜÇyüzaltı 2011-12-06 19:31:19
08.05.2020 16:25 # 5
06OzGuR06
oil & nbsp; castrol magnatec 10/40 & nbsp; & nbsp; 4 liters 65 TL & nbsp; 5 liters should be 85.
oil filter original maximum 10 TL.
Air filter original & nbsp; 15 TL.
I think you change the oil in any oil change service. They change the oil free of charge. Get the original oil filter installed there.
Buy the air filter from the original service and install it yourself.
06ÖZGüR06 2011-12-06 19:35:19
08.05.2020 16:25 # 6
serommm
There is Erkay Peugeot in Ankara. You can go there.
Behind the Acity shopping center. Mehmet Ali master.
08.05.2020 16:25 # 7
Ucyuzalti
When I first bought the car, I came to my inexperience and said I changed the oil filter, he marked there & nbsp; , I did not see what this guy got in our car got a piece & nbsp; "LOL"
08.05.2020 16:25 # 8
turcomemo
The friends returned the remaining money back to my credit card because the insurance of my old car did not end the year, the procedure was also very simple.
08.05.2020 16:25 # 9
tugrahan
& Nbsp; the same vehicle has a 1999 model 1.8 16 v & nbsp; bendede & nbsp; & nbsp; just like you said & nbsp; is a very serial vehicle as you accelerate in each gear you want a top gear to finally reach 5 & nbsp; this time & nbsp; rpm & nbsp; 4000-5000 & nbsp; the most enjoyable & nbsp; transfers & nbsp; are the & nbsp; transfers & nbsp;
electric & nbsp; dismantle the dashboard & nbsp; small small lamps & nbsp; renew them & nbsp; wear the missing ones & nbsp; it looks like glass & nbsp; I use castrol magnatek & nbsp; but in the new oil change, & nbsp; total quartz & nbsp; 5/40 & nbsp; or mobil 1 & nbsp; Mobile that I will use 0/40 & nbsp; is more expensive & nbsp; castrol and total normal levels & nbsp; also & nbsp; our cars get oil like & nbsp; 4.75 lt & nbsp; i mean & nbsp; i get 1 liter of oil in a 4 liter & nbsp; it remains a bit in 1 liter & nbsp; hydraulic dissection & nbsp; mine was tough & nbsp; 195/50/15 & nbsp; had rubber & nbsp; 185/55/15 & nbsp; fitted & nbsp; i mean the tire tread & nbsp; slightly shrunk & nbsp; very soft softening & nbsp; but & nbsp; other it is a bit harsh compared to many cars & nbsp;
if you have trouble, you can get it from the internet & nbsp; I can not find it here but I can easily find every part on the internet
< / div>
use it without a crash and a nice day
08.05.2020 16:25 # 10
Ucyuzalti
http://www.youtube.com/watch?v= XscLPphip9I & amp; feature = related
Friends Is the display showing the temperature next to the clock in this video 306 griffelerde my plain clock & nbsp; yano that side is empty
08.05.2020 16:25 # 11
Ucyuzalti
On the bad side, I can go 90, my foot is swollen, I will die with 90, I said I will die enough, I left the shoe and took 140-160 handlebars & nbsp; "LOL" I gave half a throttle, I did not give a bidet lpg, although it is 1.6, it is a beautiful country
08.05.2020 16:25 # 12
alfa
the problem in the speedometer says i will peugeot authorized services make some salty bills. Meanwhile, good luck with the new vehicle will give you a peugeot master & nbsp; of course you can fix other deficiencies of your vehicle, who & nbsp; No matter what price he says, he can't say anything, but I don't think he'll be surprised enough.
08.05.2020 16:25 # 13
turcomemo
5 liters of mobile 10/40 oil, air filter, oil filter, oil dipstick replacement + vehicle appraisal total price is 170 pounds, maybe you will say a little more but at least I am comfortable. At the top right of the radiator, there is a crack in the place where there is a valve for bleeding, the car is constantly decreasing water. I wonder if anyone has happened to such an event before?
