How should I print Red 206 + 195 45 16?
08.05.2020 18:49 # 1
sahbaz24
Friends 2 3 weeks ago I bought a second set of wheels for my car and I did it for 1 week, I made it very hard, I think I made it from scratch when I said sand paint paint, I painted my bmw m smoke gray color and bought my performance tires 195 45 16 kumho kh 31 however, we have become troubled, the vehicle that is the subject of pressing the vehicle, even when it is 4, while the slope is going out, the bgn rear tires have swept the rear fender ends. I learned how to print this torsion, I will use it in a healthy way. I'm getting a little depressed, I'm asking for the help of my friends, I'm a little obsessed man so I want a definitive solution ..
08.05.2020 18:49 # 2
Barut
Are you sure the rims are suitable for the vehicle?
My 206 has 5 springs and 17 rc wheels and 6 people got on the slightest friction.
If your vehicle is already rubbing, the rims are definitely not compatible.
08.05.2020 18:49 # 3
sahbaz24
The subject is not the bow, it is not the front, there is no problem on the rear torsion rim, the tire edge is very lightly swept, I almost got a straight wall style uphill 4 people are only ten flattened torsions in your vehicle?
08.05.2020 18:49 # 4
Barut
[QUOTE = sahbaz24] The subject is not the bow, the front is not the subject, the rear torsion has no problem on the rim, the tire edge is very lightly swept, almost flat wall style I went uphill 4 people your car is only ten flattened torsion? [/ QUOTE] of course low in torsion In the case of 6 people got on the hill, the slightest friction did not occur, but if the appropriate rim was installed. Check the offset and ett values of the rims, I think.
08.05.2020 18:49 # 5
sahbaz24
Well, I'm in a state of mind, the rims have low flesh, but I remember 16.5 die, it's a little out there
08.05.2020 18:49 # 6
Barut
[QUOTE = sahbaz24] Well, I'm in a state of eating mind, the rims have low flesh but I remember 16.5 die is a little out there [/ QUOTE] If I remember correctly, it must be 28.
08.05.2020 18:49 # 7
sahbaz24
Well, is the vehicle falling more or gasoline vehicle?
If I take a 3.5 bow and think a little bit, how can I not touch the back of the head?
08.05.2020 18:49 # 8
Barut
[QUOTE = sahbaz24] Well, will the vehicle fall more or gasoline vehicle?
If I buy a 3.5 spring, if I think it is a little bit, how can I use it in this way?
In other words, the heavier the engine, the more it falls ... There is no problem in those who do not press the back torsion. Red dream 2014-10-04 23:24:27
08.05.2020 18:49 # 9
sahbaz24
I know the tool 1.4hdi also 3.5 does not fall, now if I put 5 bows without touching the torsion, the head feels like it grins up at the back, if they can throw the pictures if there are friends who use it in this way, they will be great.
08.05.2020 18:49 # 10
samet206
It can be made from ET values because if the rim is compatible, if you do not press it, it does not rub the rim originally. 3.5 back 1 tooth is almost equal, back and front but generally the structure of the 206's head is flat back. beter originally :)
samet206 2014-10-06 01:52:29
08.05.2020 18:49 # 11
sahbaz24
Thank God, God bless you, all of us have trouble with us without trouble. My trouble is actually getting torsion when I pull the torsion worse. I am afraid of him. If it stays like this, it is not possible to have 1 finger lower back, but now if it is pressed well at 3.5 bows, this time it will be more flattened.
08.05.2020 18:49 # 12
sahbaz24
If the current gentlemen have friends who only wear 3.5 springs and use the torsion without touching them, let's get the comments even the pictures =)
08.05.2020 18:49 # 13
samet206
3.5 cm spring does not press the tool, the master drops the torsion, when it drops about 3.5 - 4 cm, this means the dimensions of the 1 tooth. If you want to look at it, they would set an apparatus when ET didn't fit the rims, because it was on the rim, because it was 15 rims and it was on the back with its original, it was 17 and it was on the smooth ride. I will add it to the subject. It may seem disproportionate when it is that way, but it is still nice and I think the health of the vehicle is important, at least important from the image.
08.05.2020 18:49 # 14
sahbaz24
Coil is very good, but I have so much budget. If you can add a picture, it would be very convenient, in fact, my kite subject is 4 people flat wall style, while the ramp is coming up the rear tires, I came to the definite opinion.
08.05.2020 18:49 # 15
samet206
Unfortunately, I did not find any pictures in Plus, but there were some of them in the way I came across the pictures.
samet206 2014-10-06 02:19:22
08.05.2020 18:49 # 16
DeRyCK
In this way, it is not very healthy, the back of the vehicle stays in the air like a stork. You can open the rear fenders a little, otherwise it will rub because the ET value of the rims on it does not match.
08.05.2020 18:49 # 17
sahbaz24
There is a 5 cm spring in this vehicle, but it is definitely 3.5 spring presses at most 2 2.5 or I thought the event of opening the rear fenders, but I looked at the distance, I do not know if it should be opened 3 cm or something, but I do not want to be like a horse carriage when the torsion hardens.
08.05.2020 18:49 # 18
sahbaz24
No current gentlemen comment and use it this way?
08.05.2020 18:49 # 19
sahbaz24
I made my decision and bought my 5 cm apexi sports springs bgn =) thank you for all your ideas ..
08.05.2020 18:49 # 20
206plusxx
I wrote the same problem in me, I put 16 inches 195 45 I put wossen backs kurt I went to any bodywork master, I crushed the rear fender chandeliers 1 I dropped it 1 torsion does not knock if it sits on 5 people now
