how much will it cost to remove a torpedo
08.05.2020 17:38 # 1
206 ersan
friends, there are some sounds coming from the torpedo of the car, when the vehicle is idle when it is not moving or when the engine is cold, it will explode or disassemble if it is difficult to remove.
08.05.2020 17:38 # 2
rolandgarros
http: //forum.peugeotturkey .com / forum_posts.asp? TID = 28451 & amp; title = own-206nn-ustas-ol-link-refreshed
the guide in the link should be illustrated, I think if you are sure that you can solve the problem, you can disassemble it yourself, otherwise familiar it is useful to look at a master "Thumbs rolandgarros 2013 -05-27 23:13:17
08.05.2020 17:38 # 3
Alicilik
While people with pimpiris do not even remove the tape because their originality will deteriorate, you want to remove the whole chest. I watched in a video, it is a very long and laborious job. If I was going to do it myself, I wouldn't want it for less than 150 just because of the jewelry. They want 20tl to tape recorder. Reviews
08.05.2020 17:38 # 4
qqyyxx
what kind of trouble do you have. Before the sting, the diffusers that are combined with the silicone spray on the glass can be seen wherever we can see the center console. Let's see what the sinuc happens. They also do not guarantee that the sound is cut off.
08.05.2020 17:38 # 5
Barut
Torpedo removal is a very laborious task, they want around 400 500 around us, this price is in most places if I am not mistaken.
08.05.2020 17:38 # 6
samet206
As said, removing the torpedo requires clean and meticulous workmanship. The job must be competent, without any clip breaking the nail, so it must be collected in the same way, and this is not such a cheap job, but to remove the torpedo is laborious.
08.05.2020 17:38 # 7
emre_akdag
We give 250 TL + VAT to torpedo removal-plug operation in Bursa :)
08.05.2020 17:38 # 8
206 ersan
There is a click that I thought I came from under the torpedo. After I listened to a master in the car, I will decide what to do after the bidet is bent from the plastic sun.
08.05.2020 17:38 # 9
qqyyxx
[QUOTE = 206 ersan] I have a click that I thought I came from under the torpedo. After I listened to a master in the car, if I decide what to do, if the bidet is torn under the torpedo, I want to fix it in a crooked place when the tornado is torn under the tornado. no, but it does not necessarily stand out [/ QUOTE]
are you talking about the middle side of the torpedo glass side?
08.05.2020 17:38 # 10
206 ersan
[QUOTE = qqyyxx] [QUOTE = 206 ersan] I have a click that I thought it was coming from under the torpedo. After I listened to a master in the car, I want to fix it if it is bent from the plastic sun, if the bidet is torn under the torpedo, the problem is where the glass meets the bent, if it is broken under the torpedo. trapezoid does no harm to me but it does not necessarily stand out [/ QUOTE]
are you talking about the glass side of the torpedo right in the middle? part unfortunately
08.05.2020 17:38 # 11
qqyyxx
I have already mentioned that I have written about this subject to you that the middle part of the middle part is in the 206s. So there is no problem.
08.05.2020 17:38 # 12
Good luck if you want to remove it completely
08.05.2020 17:38 # 13
It may also be a benefit to review this site.
http://bug206.blogspot.com/2009_03_01_archive.html
08.05.2020 17:38 # 14
206 ersan
[QUOTE = qqyyxx] I have already mentioned, I wrote to you on this subject that the middle section of the middle section is in all 206. No problem. [/ QUOTE] I am aware of a general problem, I saw a lot of 206 in my 206's except my vehicle, I thought that if I clicked from somewhere in the torpedo, maybe I will remove it when it is removed.
08.05.2020 17:38 # 15
206 ersan
[QUOTE = hLL 206]
It may also be useful to review this site.
[/ QUOTE] thanks they showed all the details almost hard but really hard work
08.05.2020 17:38 # 16
206 ersan
[QUOTE = 206 ersan] [QUOTE = qqyyxx] had already mentioned that I wrote to you about this issue in the middle of the whole section. I don't know. [/ QUOTE] problem is a general problem, I am aware of the problem in the 206s. I saw a lot of 206 other than my car, in many of them, I thought that if the clicks were somewhere in the torpedo, maybe I would remove it when I was ready to remove it [/ QUOTE] in the bidet 206. The problem is the crack in the right passenger airbag cover does anyone have information about how to disassemble and repair it
08.05.2020 17:38 # 17
qqyyxx
[QUOTE = 206 ersan] [QUOTE = qqyyxx] had already mentioned that I wrote to you about this issue in the middle of the whole section. No problem. [/ QUOTE] I am aware of a problem that is general problem. I saw a lot of 206 in my 206s except my vehicle. br>
brother, it's okay, it's the structure. That is the structure of the torpedo.
