How much maintenance amount do you think
08.05.2020 20:41 # 1
Daimon
2006model 1.4 173000 I want to put my car in service 1-front set complete 2-rear wheel bearing left side 3- lower engine mount complete 4-bolt 5-front disc pad 6- rear pad 7-oil maintenance 8- finally throat butterfly cleaning them I want you to have it made, what is the cost of friends, whether parts are original or sub-industry + workmanship
08.05.2020 20:41 # 2
Selox
It looks like it costs around 1500. Of course, on the front set that depends on the parts to change. maybe something else comes in the back. I write the average.
08.05.2020 20:41 # 3
I definitely recommend using the 1-front team, my brother trw - rıw - valeo - delphi - magnet marelli brands, it is a little expensive but it will be more durable and long lasting. Take out 1000 TL, brother. There may be minor changes in prices depending on the location.
for trw brand
tie rod end -30 tl x 2 = 60 TL
z rot -30 tl x 2 = 60 TL
tie rod -35 tl X 2 = 70 tl
swing (table) Delphi -90 tl x 2 = 180 tl
disc front valeone - 120 TL
lining front trw - 65 TL
rear wheel bearing secr - 50 TL
rear wheel lining valeo - 60 TL
lower engine mount bushing - 25 TL
spark plug - 50 tl 4 (pieces)
engine oil 4 liters 10w / 40 - 60 tl (total)
air filter - 20 tl
pollen filter - 20 tl
petrol filter - 15 TL
oil filter - 15 TL
workmanship - It varies between 150-250 TL according to the master
sonerkyl 2017-12-12 13:38:27
08.05.2020 20:41 # 4
Daimon
Thanks, it turned out exactly as you wrote .. They asked for 400/450 of workmanship.
08.05.2020 20:41 # 5
Daimon
[QUOTE = Selox] As if it cost around 1500. Of course, on the front set that depends on the parts to change. maybe something else comes in the back. I write the average. [/ QUOTE]
Thank you very much.
08.05.2020 20:41 # 6
Selox
[QUOTE = Daimon] [QUOTE = Selox] as if it cost around 1500. Of course, on the front set that depends on the parts to change. maybe something else comes in the back. I write the average. [/ QUOTE]
You're welcome bro we memorized :)
