How much does my 307 vehicle have to change parts?
08.05.2020 19:15 # 1
tutuman_307
PEUGEOT 307 REAR SHOCK ABSORBER UPPER WEDGE x 2514232RP33,90 TLPEUGEOT 307 REAR SHOCK ABSORBER (DJ) x 25206V9DJ118,64 TL I made my sparch during my meeting with the peugeot, it would be more appropriate to change 2 of them at once and the upper wedges should be changed. I learned that it was from his balls and gave my sparring. How about I work on replacing these parts on average?
08.05.2020 19:15 # 2
KIZILASLAN
average 100 lira or something
08.05.2020 19:15 # 3
SiYAH
I went to the private service. I took small things like Rotbasi motor ear. The man said, "Ask me while I buy them again. I said, "I am okay with my purity. I understood what he meant when he asked for 300 liras in workmanship. Later.
08.05.2020 19:15 # 4
oguz41
I did not want to open a new topic. I am asking my question on this issue. I was the one who changed the gasoline circuit clutch brake pad. I think I got a price of 600 TL.
08.05.2020 19:15 # 5
a little flying friend here, if there are 250 prints, if it takes 200 labor, if it holds 30 TL oil, it should be an estimate like 480, it should not be over 500, and if we add clutch bearing, it is normal.
08.05.2020 19:15 # 6
oguz41
[QUOTE = sonerkyl] a little flying friend here, if it is 250 prints, if it takes 200 labor, if it holds 30 TL oil, 480 number should not be over 500, but if we add clutch bearing, we can say it is normal [/ QUOTE]
I understood it was cold, thank you.
08.05.2020 19:15 # 7
Gokcesel
Sir, I will also change the press pad, clutch set 200 transmission oil 35 and a lathe work will be done, he said 200 in 30 TL of labor, making a total of 465 TL, reduced to 450 TL in a flat 206 diesel in my vehicle
08.05.2020 19:15 # 8
oguz41
[QUOTE = Gokceel] Sir, I will also change the pad, the clutch set is 200 transmission oil 35 and a lathe work will be done, it said 30 TL in labor 200, it makes 465 TL in total, straight down to 450 TL 206 diesel in my vehicle [/ QUOTE]
very good price according to here but my print is a bit expensive i guess i searched on the internet around 245 but still very nice price let me ask elsewhere.
08.05.2020 19:15 # 9
Gokcesel
[QUOTE = oguz41] [QUOTE = Gokceel] Sir, I will change the press pad, clutch set 200 gear oil 35 and a lathe job will be done, 30 tl of work 200 said, making a total of 465 tl, lowered to 450 tl 206 diesel in my vehicle [ / quote]
Since the price in my vehicle is familiar to 225 liras on the internet, we get the clutch set to 200 liras. I hope you get the price you want. Thumbs Up
