How much does it burn 100 km
08.05.2020 16:57 # 1
scepter
good evening i bought a new car 0 km 2012 206+ urban move 1.4 hdi 70 hp & nbsp;
how much it burns in the city
how much does it cost 100 km out of the city
in the city when the air conditioner is on and how much does it cost
diesel price here: 3.93
08.05.2020 16:57 # 2
muratozhal
First of all, I wish you a good day without accident and punishment, good luck :) If you measure it with a full tank, you will reach the final result. You can measure inside the city outside the city. It varies from use to use. Of course, try not to fall below 2000 cycles.
08.05.2020 16:57 # 3
sezar206
I use the gas vehicle 15 & nbsp; - I burn 16 lira between 90 - 110 km speed. You calculate it accordingly. Both the diesel vehicle and the pejo are elegantly made of fear fuel.
08.05.2020 16:57 # 4
scepter
[QUOTE = fatihpekgoz]
I used the gas vehicle 15 & nbsp; - I burn 16 lira between 90 - 110 km speed. You calculate it accordingly. Both the diesel vehicle and the pejo are elegantly made of fear fuel.
will there be much difference when the air conditioner is on
08.05.2020 16:57 # 5
sezar206
If it burns 15 krs then come on 17-18, it doesn't matter much. I open it on the long road, I swear the air conditioner inside the car. There is no exaggerated difference in traction either. I don't know if it might be noticeable on the 1.4 gasoline, but I don't think you will notice it in the car.
08.05.2020 16:57 # 6
toga406
I think it will surely say that it will burn less than 5.5 liters in the city.
08.05.2020 16:57 # 7
muratoner
Yes, I agree with my tolga brother, if it is 21-22 kurus in the city, it burns around 18-19 kurus, but it varies according to this driver.
08.05.2020 16:57 # 8
Alicilik
Fuel consumption is directly proportional to traffic density - high speed use and hilly roads.
I go to school in the morning and return home in the evening. I'm going 14km in average 45 minutes. It is not aggressive, but I use a little high speed. Road works are more or less uneven. The trip computer displays 5.7 fln, but when I measure it, 5.4 fln is output. Of course, if I use calm and avoid traffic, I even saw 4.6. Believe intercity burns less than you think. 200km in very quiet use, only the needle played half.
If you use the diesel vehicle in a calm and revolving time, the floor and floor ideal from LPG you will understand this most on the intercity road.
There is no incident such as burning more and burning more in air conditioning. Air conditioning does not increase existing fuel. Just because it uses the traction of the engine, there is a decrease in performance. The person who wants to turn it off will be loaded into the gas. The car will be very burned. I opened the air conditioner at the last level, nothing changed, but the speed of the vehicle fell slightly.
08.05.2020 16:57 # 9
mrkync
An example ; 2005 Model Peugeot 307 HDİ Look 1.6 110 Bg
When I came back, I said the retarded pump fuller, the vehicle was pouring the excess diesel, so the tank was full. Bolu - Isparta round trip went 1250 km. When the Bolu Mountain came out, the fuel lamp burned. & nbsp; As your friend says, when I drive calmly, the car burns 3.4, 3.5lt / 100 km. & nbsp;
08.05.2020 16:57 # 10
omer_tarsus
I went more than 1000 km with 1 depot outside the city, around 200 km in the city. The average speed outside the city is 110, I even saw 160 in some places. So 100 km lit 5 liters
08.05.2020 16:57 # 11
KenBlockJR
you will catch the values such as 4,5 - 5,0lt / 100km between cities. 3.5 is possible even with 90 constants KenBlockJR 2012-09-19 19:18:05
08.05.2020 16:57 # 12
BUNYAMIN
Friends, I bought zero km 206+ urban diesel, the first time I bought it, it burned an average of 30 krs per km, now it is 2800 km to my car and an average of 29 krş in the city. It burns and when do you think my car returns to normal.
08.05.2020 16:57 # 13
Serkan
My vehicle is still not back to normal in 116 thousand, burning 29.5 Krs.
08.05.2020 16:57 # 14
Engin ASLAN
teacher, those who say 15-16-17 cents burn in this lpg, I could not fall below 23, I did not understand how you do it, I am calculating wrong or you
08.05.2020 16:57 # 15
pierson
Either friends, how little the diesel burns ... neither gasoline nor lpg ... lpg is the best ... if it wants to be ... then repentance gasoline lpg liye ... let it be completely diesel ... so what are the cons of diesel? .. what's wrong with it compared to other cars
08.05.2020 16:57 # 16
Serkan
Those who say [QUOTE = enas] teacher is burning 15-16-17 cents in this LPG, I could not fall below 23, I do not understand how you are achieving, I am calculating wrongly or you [/ QUOTE]
It burns 17 krş is correct, but stop and stand 29.5 krş in short distance use & nbsp; I drop to 22-23 krş if the distance gets longer and I take the e-5 in comfortable traffic.
08.05.2020 16:57 # 17
tellotello
[QUOTE = Serco05] [QUOTE = enas] who said that my lpg is burning 15-16-17 cents in this lpg, I could not fall below 23 I did not understand how you do it, I am calculating wrong or you are [/ QUOTE]
My teacher outside the city 80 It is true that it burns 17 krş when traveling with -90 but stop and stand 29.5 krş in short distance use & nbsp; I fall to 22-23 krş if the distance gets longer and I take the e-5 in comfortable traffic.
Well, it's the same situation. Especially, both the uphill and the stop-and-go traffic are 30 cents. Then the straight road, I saw the empty road, turning the eye, cannot show more than 4 liters of the car trip computer & nbsp; "Big. Our 1.4s can't pull 1250 kg stop and stop in traffic o another situation & nbsp; "Smile".
08.05.2020 16:57 # 18
serkan719
I usually go in 2000 or 1800 cycles.
I don't mind this.
The engine does not vibrate.
08.05.2020 16:57 # 19
Burak
I burn 50 cents with gasoline in Istanbul traffic :)
08.05.2020 16:57 # 20
Serkan
[QUOTE = serkan719] I usually go in 2000 or 1800 revolutions.
Page : / 2
