How much do you think it explodes ??
08.05.2020 16:58 # 1
ahmetismet
My friends car routine 10,000 maintenance came and even 500-1000 passed. Engine oil air filter or something will change. There is no urgency, but my car is diesel, the spark plugs need to change now. My clutch is hard and gripping up, I want to replace the press pad. And when I put the wiper water, it flows down directly (I hope the wiper motors are not broken, only the tank seal is out). Because I do not know any masters in my place and it is quite a bit since I did not take it to the authorized service, I would say there is a service record :))
08.05.2020 16:58 # 2
berk2309
my teacher holds about something to 1, besides I don't know what the price is, the price is very low, but I do not think the materials do not hold much, but it is quite a bit, but I think it will be a little bit more.
08.05.2020 16:58 # 3
ahmetismet
I guess there is no one going to the authorized service ..
08.05.2020 16:58 # 4
I guess they give a price between 900 TL and 1000 TL.
08.05.2020 16:58 # 5
Serkan
Hodja, even if you change the pressure pad outside, it will not be lower than 400 lira, the service can double, and when you say maintenance spark plugs or something, they will increase between 1,000-1,200. Call any service, say the chassis number, at least you can find out how much the pressure pad will cost.
08.05.2020 16:58 # 6
brutal
The amount of 1300-1400 TL is the worst raid launcher will already hold 400-500.
08.05.2020 16:58 # 7
ahmetismet
1400-1500 is not very much in 900-1000 neys ..
08.05.2020 16:58 # 8
Serkan
My friend now called mepa service, they only gave 1.000 TL price for printing pad replacement. Its number is 212 698 44 44. If you do not know the number, you will know 1,500 TL.
08.05.2020 16:58 # 9
ahmetismet
The father-in-law has a acquaintance, and now I will ask him.
08.05.2020 16:58 # 10
marmarascorpion
Make sure you don't keep it below 1500 in the authorized service, if you go to the private service, it will not fall below 1000 liras. If you are familiar, maybe you can drop a little more.
08.05.2020 16:58 # 11
If you do not have reliable masters such as press brake, timing, etc., in the industry, you can book it at an authorized service center. You can also negotiate at the authorized service, they will discount if you are determined.
08.05.2020 16:58 # 12
gozem
In my opinion, let the master of the decision of the replacement of the press brake do not incur other costs. If removing the heating spark plugs alone, if they break their heads, this time the engine top cover will need to be removed. and the expense is 2 times 3, so you have to find a safe master to take charge of it
08.05.2020 16:58 # 13
ahmetismet
[QUOTE = eye] I think, leave the decision of the press pad replacement to the master, other costs will not cost you big. If removing the heating spark plugs alone, if they break their heads, this time the engine top cover will need to be removed. and the expense is 3 times 2, so you need to find a safe master who will take the responsibility of it If they do not take such a responsibility, nobody will take it ... If he needs to remove the engine cover in case he could not make a master, will he also reflect his cost to me? & nbsp;
08.05.2020 16:58 # 14
serkan206
1000 clean ...
08.05.2020 16:58 # 15
izorya
I just changed the printing pad. I asked the private service, 600tl said. I had a familiar master, I changed it to somewhere through it, I changed the piece to 250 + mastery 150 = 400tl.
08.05.2020 16:58 # 16
ahmetismet
super price, let's see how many tl prices they will give me to the authorized service that i will go tomorrow ... i share it here ... / edited>
08.05.2020 16:58 # 17
ahmetismet
Friends I got 1000TL price for all the transactions I wrote above from the authorized service. It seemed reasonable to me, I gave the vehicle tomorrow ...
08.05.2020 16:58 # 18
Serkan
Nice price buddy, mepa only wants 1,000 rubles to print pad set.
