How Much Air Should I Press on the Tire?
08.05.2020 19:39 # 1
Bayram96
Hello to everyone. I did not understand much from the ones written next door. How much do you think these Olculers are pressed. I would be glad if you could help. Thanks.
08.05.2020 19:39 # 2
Bayram96
http://i.hizliresim.com/rzwbvn.jpg
08.05.2020 19:39 # 3
GokhaN
standard 32 psi pressure is sufficient enough data is too high usually bar to PSI Conversions 0.1 bar = 1.4504 PSI 0.2 bar = 2.9008 PSI 0.3 bar = 4.3511 PSI 0.4 bar = 5.8015 PSI 0.5 bar = 7.2519 PSI 0.6 bar = 8.7023 PSI 0.7 bar = 10.1526 PSI 0.8 bar = 11.6030 PSI 0.9 bar = 13.0534 PSI 1.0 bar = 14.5038 PSI 1.1 bar = 15.9542 PSI 1.2 bar = 17.4045 PSI 1.3 bar = 18.8549 PSI 1.4 bar = 20.3053 PSI 1.5 bar = 21.7557 PSI 1.6 bar = 23.2060 PSI 1.7 bar = 24.6564 PSI 1.8 bar = 26.1068 PSI 1.9 bar = 27.5572 PSI 2.0 bar = 29.0075 PSI 2.1 bar = 30.4579 PSI 2.2 bar = 31.9083 PSI 2.3 bar = 33.3587 PSI 2.4 bar = 34.8091 PSI 2.5 bar = 36.2594 PSI 2.6 bar = 37.7098 PSI 2.7 bar = 39.1602 PSI 2.8 bar = 40.6106 PSI 2.9 bar = 42.0609 PSI 3.0 bar = 43.5113 PSI
08.05.2020 19:39 # 4
Bayram96
Should I press 32 in 4 tires or the front and back are different
08.05.2020 19:39 # 5
all tires are the same + as the vehicle partner I think if you are carrying loads or something, you should increase the tire pressures. If you say no, it will be enough as 32 Gökhan said.
08.05.2020 19:39 # 6
Bayram96
We do not carry up, there is a difference when it comes to a family purpose winter tire.
08.05.2020 19:39 # 7
I understood that when it comes to a winter tire, the same holiday is definitely the same, I have 32 enough or less.
08.05.2020 19:39 # 8
Bayram96
Thank you, thanks
