How many psi should 195/45/16 be?
08.05.2020 16:35 # 1
Bugra
friends I have 195/45/16 tires on 206 hdi cars. Do you have any information about how many psi air should I print?
08.05.2020 16:35 # 2
yavuz25
Usually everyone in the oil presses air between 30-28 every type of tire, but I don't know if it is wrong. "Big
08.05.2020 16:35 # 3
kuantum
Let me ask, then: 195 / 65R15 91H how many psi should it be?
08.05.2020 16:35 # 4
yavuz25
30 psi bass go, my brother.
08.05.2020 16:35 # 5
yavuz25
In fact, if we trace the original tires and tires, what air is going to be printed on the milim on the labels in the car, but here is what you will do. "Big yavuz25 2012-02-13 12:30:52
08.05.2020 16:35 # 6
kuantum
answer my question?
08.05.2020 16:35 # 7
06OzGuR06
[QUOTE = quantum] Let me ask, then: 195 / 65R15 How many psi should 91H be? [/ QUOTE]
I think 32 PSI is enough. All tires are now 32 PSI & nbsp; Normally the front and back should be different because the load is carried in the rear part. If you do not carry the back part, the front back 32 PSI is ideal. "Smile"
08.05.2020 16:35 # 8
Meric42
The bass between 29.32 was late, so you did not look at the tire 33 bass but 34 bass: D
08.05.2020 16:35 # 9
yavuz25
[QUOTE = Meric42] The bass between 29.32 was late, so you did not look for a tire, 33 bass but 34 bass: D [/ QUOTE]
so what do you say we will not all die one day. "LOL" "LOL"
08.05.2020 16:35 # 10
Bugra
Actually, there are psi values where most similar rubber air exists but I could not reach here. In the bidet, I also searched for a table with a descriptive table, but he doesn't. So it must be certain. otherwise, we can print eye decision / manual procedure necessarily "Dead" "Disapprove"
08.05.2020 16:35 # 11
[QUOTE = bugrature] actually there are psi values where most similar tire air exists, but I couldn't get it in our here. In the bidet, I also searched for a table with a descriptive table, but he doesn't. So it must be certain. otherwise, we can print eye decision / manual procedure necessarily "Dead" "Disapprove" [/ QUOTE]
There is nothing definite about this. Because the weight, shape, aerodynamic features, suspensions, etc. of each vehicle. It is different. The most accurate values are factory exit values, which are written on the tag on the pole of the door of the driver's door. If you have changed your rim-tire sizes, you should reach a data based on these original reference values. Reviews
08.05.2020 16:35 # 12
aslan7333
Regardless of your rim and tire size, 30-32 psi air should always be pressed in passenger cars.
I use 31 psi.
08.05.2020 16:35 # 13
voodoo
brother, you need to press this tire to 2.2 all four tires, this is the fabrication data ... this is in my measurements, and these tire sizes are given at the door of the sofor ... 2.2.
